DESIGN & BUILD SOMETHING PLANNER IS MOUNTED TO PERMANENTLY.
PUT FRAME UNDER THAT WITH HOLE THRU FRAME TO PASS A 2" PIPE THRU.
OTHER SIDE OF PIPE ON FRAME WORK COUNTER WEIGHT TO MAKE TURNING PLANER UP & LATCHED IN POSITION,(no more picking heavy planer up)
WHERE COUNTER WEIGHTS ARE WILL BE SMOOTH TABLE TOP, TO BE USED WHEN PLANER IS DOWN BELOW.
Gentlemen be kind, i made thru 6th grade, Thanks, olbuck.
