Showing results for tags 'flip down'.
  1. DESIGN & BUILD SOMETHING PLANNER IS MOUNTED TO PERMANENTLY. PUT FRAME UNDER THAT WITH HOLE THRU FRAME TO PASS A 2" PIPE THRU. OTHER SIDE OF PIPE ON FRAME WORK COUNTER WEIGHT TO MAKE TURNING PLANER UP & LATCHED IN POSITION,(no more picking heavy planer up) WHERE COUNTER WEIGHTS ARE WILL BE SMOOTH TABLE TOP, TO BE USED WHEN PLANER IS DOWN BELOW. Gentlemen be kind, i made thru 6th grade, Thanks, olbuck.
