Showing results for tags 'correct stain'.
Grooming something this small needs a jig so I turn the whole piece into a big jig large enough to hold on to. I screwed the Rook to be to a piece of 1/4" piece of BB. This let me hold it true for a cut on each side with the band saw. Then grind away till it matches the other one!! Used different wood so a little staining might help. I found something close. So I took it outside and shoot it with some clear to see if the color was still close after the clear Dried. I used maple and they had made the chess set with cedar. The lady thought only a few pieces with chips missing were all the set needed until the guy that got the set for Christmas let her know two pieces were missing... Now to get back to the End Of The Trail saga...
- 9 replies
- needs
- different wood
(and 6 more)
