Showing results for tags 'cnc work'.
As the rotary axis jobs don't move the X axis I thought I'd cut a handle for a parting tool I bought. Glued up a 1.5" x 1.5" x 7.5" block to use. First cut the block into a cylinder, Sorry no photo. Cut the end for the ferrule as a pocket cut first. Cut deeper than it should of, but I'll wrap it in tape to the ferrule will fit. Next proceeded with a moulding toolpath. Just over the hump so far: Then approaching the end on the CNC: Once finished: I took it out to my garage lathe to sand and trim off the end. Still needs a 1/2" diameter hole in the end for the tool. Then some finish: Other than the ferrule end being smaller than I expected and needing a fix, the handle will do the intended job. 4D
- 5 replies
- rotary axis
- cnc work
(and 1 more)
