Showing results for tags 'cnc dish'.
  1. 4DThinker
    A use for small scraps.
    Often I end up with odd shapes/corner scraps/etc. of small pieces of good wood. For example when cutting a round table top out of a square panel of wood. Thought I'd salvage some good scraps and glue them up to make a useful small board and this is one result: A simple tray/dish, perhaps to set on your dresser as a place to put you jewelry on at the end of a day or maybe a candy dish to set out for company. I don't know what I'll use this for, but I like it better than the raw scraps alone it was made from. Still need some sanding and a finish. CNC cut the top center and rounded edge, then a trip to my routerr tanle to bevel the sides 11.25 degrees, followed with a 45 degree chamfer transition to the bottom surface. Doesn't show well in this top view. Made from 3 scrap pieces you can see if you look closely. 4D
