Showing results for tags 'cedar planks'.
have the leftover planks of Aromatic Red Cedar....was try to build a small box with a few pieces.. Dry fit. Stands a whopping 4" tall, BTW... glued up, and then cleaned up when it came back out of the clamps... marking gauge to show where the tablesaw's thin kerf will go... once that was done... Had to clean up the saw marks.. And then dig through the box of hardware....to find a couple hinges..and screws.. Then a latch.. Even found a couple fancy handles for the ends... Wednesday while by Pay Day, I can get a brush or two, and varnish the outside... Tried out the Scrollsaw today....next box will use dovetails....scrollsaw to cut the "tails"... Will decide later, what the final size of Box #2 will be... Stay tuned Pins I had to do the "Old Fashioned Way" with a saw and chisel
