Showing results for tags 'boxwood rule'.
Found 3 results
  1. John Moody
    Upson Nut Co.
    Upson Nut Co Andrew Upson was the President of the Upson Nut Co which was established in 1872. The Standard Rule Co was the youngest firm in this group. Standard Rules factory was located in Unionville, Connecticut. Within three years the Standard Rule co had become the fourth largest ruler manufacturer in the United States. It is not known if they began operation from scratch or by purchasing another rule manufacturer. The Standard Rule Co. used the same nomenclature and rule numbering as Stanley. By the turn of the century most small rule makers in the United States had either ceased operations or been bought out by the large Connecticut makers. By this time virtually all the rules made in the United States were produced by Stanley, H. Chapins Son & Co., Stephens & Co., The Lufkin Rule Co., and The Upson Nut Co. which had absorbed the Standard Rule Co in 1889. In 1920 more of the rule manufactures were dropping out and it saw the departure of two competing manufactures. The rule division of Upson Nut Co and the Chapin-Stephens Co. The Upson Nut Co, now a Cleveland based manufacture of nuts and bolts had retained its rule division in Unionville, Connecticut, when Stanley purchased its hand tool division in 1893. Finally in 1922, The Upson Nut Co., abandoned the last vestige of tool making and sold the rule division to Stanley. The same day I ran across the Stanley No.1 Odd Job tool, I also found this Upson Nut Co. No. 68 boxwood rule. The round joint, the center disk was attached to a plate which was embedded in a slot in the end of one leg and held in place by steel pins driven through the leg and the plate. This joint was the cheapest, weakest and the least decorative of the three type of main joints used on boxwood and Ivory rules. Excited to add this old rule to my collection of Boxwood two foot four fold rulers. Always out Patriot Picking!
  2. I have a Standard Rule & Level Co. 26 inch long level with Ripley's Adjustment. The level had been used and abused and the Ripley's Adjustment removed. I have not been able to discover anything about Ripley's Adjustment and would appreciate any leads about it. The level has been restored to the point where it can be displayed. I doubt that it has much value because the adjustment was removed and many of the original brass screws were missing.. john.neff.ic.64@gmail.com
  3. Grandpadave52
    Friday's Pick
    I had some time to kill late Friday afternoon waiting for my wife to get off work so we could pick-up the truck from the transmission transplant. I hadn't been to the local flea market since well before Christmas...Pretty much the same 'ole, same 'ole. On the way out one booth has a variety of tools but most are of little value. I did however stumble upon this laying under some junk. @John Moody you wanted proof and more details of the find. So you know, I trudged out to the garage today, 18o, wind blowing, barefoot, waist high snow, uphill both ways to find my magnifying glass. Here's the results. How did I do? This is a "four fold" right? Any ideas on the approximate age? I hope to clean it up a bit but not ruin the patina. I stumbled upon an article Chris Schwartz wrote about how he cleaned one using diluted oxilac acid wash I'm not sure yet how to reattach the brass strips but was thinking maybe CA glue? Thoughts. Stanley-Sweetheart No. 62 Boxwood & brass folding rule; Besides the U.S.A. it is stamped Boxwood. Only one of the three alignment/latch pins remain; brass edge strips have pulled or been pulled from brass pins; some debris under the strips Thanks for looking.
