Showing results for tags 'auxiliary fence'.
  1. Reminded myself this morning of teaching days when students were afraid of cutoff kickback and cutting small parts on the big compound miter saw which I also own. I drew up these to cut out for my own saw, and I'll send the file to the college lab manager. The saw has 1/4" x 1/2" holes in the metal fence already. I'll add a photo of them mounted on the saw after I cut them out later. Prior to this I've just used small c-clamps to clamp on plywood scraps. These will use t-bolts I already have and either cam levers or wing nuts on the back side to loosen/tighten or remove them. The gap between the metal fences is indeed a danger. This will be a permanent attachment to my saw so I can put my tiny c-clamps to other uses. The wide slots allow me to pull them 1" away from the blade, then I can loosen the metal fence they are attached to and slide it back for miter cuts. I'll cut these from a scrap of cheap 1/2" thick birch veneered plywood I have. 4D
