Showing results for tags 'assemble stand'.
Thought I would post this over here in the "SHOPS" section where I could "tag" it if someone else was looking for ideas. As I have mentioned in previous posts, I have been working on a Table Saw Storage unit for under the extension table and an outfeed table. I have combined the two so I can store the outfeed table out of the way when not needed. I can also use this as an assembly table. I used 2 motorcycle lifts to raise the cabinet off of the base to level it with the table saw. Since my floor is somewhat uneven, I went with 2 lifts so I could adjust for a slight slope (if needed) and for more stability. Here is the base with the two lifts and casters attached (not many PIP photos) Under the extension table in "storage" Showing 3 of the 6 drawers (sorry it is blurry) Showing the blade storage in the back In position as the outfeed table View of the lifts under the cabinet The entire cabinet is made out of MDF (scraps I had) and the base is from a failed project a few years ago. Projects like this help me use up some of the scraps that I have accumulating around the shop. Thanks for looking
- 11 replies
- shop storage
- outfeed table
(and 1 more)
