Showing results for tags 'air die grinder'.
Hey I don't want to suggest something you might not want but for what you suggested you are in to, an air grinder should be considered if you have a reasonable sized compressor and not the screaming kind. Because die grinders take 1/4" bits they can hog off more material than the 1/8" bits I prefer on carving. Also Wood Carvers Supply has the bits in 1/4" size and will do the same as the 1/8" bits I use but much faster.. Also if you don't have yet, Bring up Wood Carvers and check out their 2" carbide nugget wheel # 264866....and hold on to your hat for it will throw wood all over the place..Also a chain saw wheel will get after wood real fast but it will do the same to skin and bones the same way!! I can trust their air tools way more than their electric models. I have maybe ten different HF air tools and only one electric and all they need to last a while is light weight oil... But you do have to be careful about the amount of oil when used around expensive wood.. These have front and also rear exhaust so the rear exhaust model would be the one to buy. The last two I bought from HF is their 13.99 and the 19.99 1/4" angle grinders ...They also have the small 5/8" diameter pencil grip size air grinder for 1/8" bits and will be the next I buy..24.95 and will be cheaper with that always 40% off of any one item.
- 2 replies
- grinder
- air compressor
(and 2 more)
