April 22, 201313 yr comment_14244 I am working on 2 shadow boxes for my military related items. The first one is designed to hold the various velcro backed aviation patches I've worn over the years. My goal was is to take advantage of the velcro backing and "stick" them to the shadow box backing. However, this is presenting a challenge. I quickly dismissed flocking as the velcro would not stick (on a test piece). Next I thought of the fuzzy pile that is made for velcro but it just does not look right and large amounts are more expensive than what I wanted to spend. Now I got a couple of yards of black felt but am not sure how to attach it. Would spray adhesive work without bleeding through?I'm worried that a spray adhesive will start letting go over time (though I admit, i have'nt used it much and not real familiar with how well it works). Any suggestions?Thanks,KevinKevin WellsChuckin' Woodwww.chuckinwood.com Report
April 22, 201313 yr comment_14249 I'm not sure whether your patches have the hook or the loop but you could try felt.Ron DudelstonSite AdministratorAbove and Beyond WoodWorks Report
April 22, 201313 yr comment_14248 The spray adhesive should be fine. I have used it in the back of some shadow boxes that were used to display golf clubs. Report
April 22, 201313 yr comment_14247 Kevin, could you purchase a small roll of the velcro material, cut it in small squares, glue it to the back of the case after you have applied the backing of choice, just glue the velcro to that, then stick your patch to it. I would be hesitant on adhering your patches permanently. Report
April 22, 201313 yr comment_14246 Kevin, I have used spray and brush-on adhesive to apply felt to wood. Â Both work without bleeding through the felt. Â I found that the spray is better (watch out for the over spray) because it can be applied more evenly. Â I've done this to my gun cabinets and Navy Charge Books. Â Even after 15 years, you can't see any trace glue and the red felt looks perfect in my gun cabinet. Â Hope this helps. Report
April 22, 201313 yr Author comment_14245 Thank you for the responses. I hope to finish the first one this weekend. I'll post pictures when I do.Kevin Report
