October 1, 201313 yr comment_8540 Has this ever happened to you?  I have been confronted with an almost impossible problem: EVERYTHING IS A MESS AND THERE'S NO PLACE TO PUT ANYTHING [insert string of horrible vulgarisms here]~!!  I have two workbenches and a 7 x 4 foot torsion box assembly table. They are all covered with crud. I pick up something to put it away only to find that the only place for it is where I picked it up from. I can't put up shelving because My wall space is spoken for I can't really reorganize the shop because I have a mess of equipment the old 10 pounds in the 5 pound bag problem. But then I looked up. And Light Dawned over Marblehead ( a Mass' bay colony reference) I have a flat roof with a recreational deck over my shop and in between the ceiling joists is space just low enough that I can touch the joists if I stretch. I can make shelves 6 &1/2" deep by 4' long and suspend them from the joists and nest them in between the joists. So I made up one of these from some ply scrap: It hangs by a single heavy duty hinge Here it is all tucked away I liked it. I went to the lumber place got three sheets of half inch ply and am making 6 more just like that. I'd been struggling with this problem for a while and I think this may be the ticket. Plus it may give me some insulation too Report
October 2, 201313 yr comment_8551 Apparently, great mind do think alike Lew Kauffman-Wood Turners Forum HostTime Traveler and Purveyor of the Universe's Finest Custom Rolling Pins! Report
October 2, 201313 yr comment_8550 Cliff that is pretty danged cool! Now I wish my ceilings in my garage were not finished! Heck, I may just have to go out there and start ripping the drywall off my ceilings just so I can do this too! Great storage idea, sharing on Facebook, great tip! John MorrisThe Patriot Woodworker Report
October 2, 201313 yr Author comment_8549 Well you could just cut into the sheetrock and finish the opening. If you used AC ply you could mud the face that fronts down into the shop and paint it like the ceiling. That way it'd have a real slick finished look.One thing I have considered is how to remember what is where. After all it's a closed box until one opens them. A list in large bold print maybe? Report
October 2, 201313 yr comment_8548 Cliff,How heavy is it to lift up into it's place?Gene'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton Report
October 2, 201313 yr comment_8547 Pure genius! I may have to add a few to my shop. You should send that in to popular woodworking and fine woodworking magazine and see if they will will publish it in tricks of the trade. Report
October 2, 201313 yr comment_8546 I labeled all the sand paper boxes on the out side, but the rolls I just read from the printing. Since that pix, I made another drop down beside this one for my Velcro discs and rolls. Cliff said:Well you could just cut into the sheetrock and finish the opening. If you used AC ply you could mud the face that fronts down into the shop and paint it like the ceiling. That way it'd have a real slick finished look.One thing I have considered is how to remember what is where. After all it's a closed box until one opens them. A list in large bold print maybe? Report
October 2, 201313 yr comment_8545 Great Idea!!! My ceilings are finished and have insulation on top. John MoodySite Administratorhttp://www.johnmoodywoodworks.com“Don’t make something unless it is both necessary and useful; but if it is both necessary and useful, don’t hesitate to make it beautiful.†Shaker Saying Report
October 3, 201313 yr comment_8544 Great solution and it's bound to work well. Â But...and I don't mean to rain on any parades but there is a structural consideration since it does add the potential for quite a bit of additional weight added to what the joists are being expected to carry. Â Don't know what your local wind load and snow load codes are, but if it were here in Colorado it would be fairly easy to load those joists spaces to a potentially dangerous level. Â This problem is mitigated quite a bit if you keep the load (the hinge end of the cabinet) as close to the wall as practical, avoiding the center of the span of the joists if possible. Report
October 3, 201313 yr comment_8543 For me, mine is in the basement- below a bedroom. Neither really weighs very much so I think I'm OK.Ron Southard said:Great solution and it's bound to work well. Â But...and I don't mean to rain on any parades but there is a structural consideration since it does add the potential for quite a bit of additional weight added to what the joists are being expected to carry. Â Don't know what your local wind load and snow load codes are, but if it were here in Colorado it would be fairly easy to load those joists spaces to a potentially dangerous level. Â This problem is mitigated quite a bit if you keep the load (the hinge end of the cabinet) as close to the wall as practical, avoiding the center of the span of the joists if possible. Report
October 9, 201313 yr Author comment_8542 Ron Southard said: there is a structural consideration since it does add the potential for quite a bit of additional weight added to what the joists are being expected to carry. Report
October 12, 201313 yr Author comment_8541 Gene Howe said:Cliff,How heavy is it to lift up into it's place? Report
