October 19, 201313 yr comment_8138  Over and over I've read that cross grain glue ups are doomed to failure due to humidity and wood movement. Of course it begged the question of how table aprons stay connected to legs in mortise and tenon glue ups - some for hundreds of years too. Anyway I decided to see if I could wreck a cross grain glue up with wood movement I put a couple of pieces of wood together of differing thicknesses of Siberian Elm. The glue Titebond III Several times I soaked them for days at a time in a bucket and left them to dry in full sun plus they spent a year out of doors in the weather.  Pic 1 & 2 is the glue up after a year. Next pic is the glue up in my vice with my trusty Trimo wrench about to tear the joint asunder And the results I think it is fair to say that the glue line did not fail. Next I suppose I should do a joint that all the experts warn will absolutely positively of a dead true certainty fail. I'll try a nice wide glue up like bread board ends Not the cute little tenons the experts all recommend but full board with cross grain. Maybe I'll get carried away and  do a regular glue up like a regular bread board would have and see what that results in. I think it's good to test the advice of the experts don't you? Report
October 20, 201313 yr comment_8145 Nice test, Cliff. Just a side note regarding your last couple of paragraphs. Many years ago, I made a trestle style hobby table for a friend. It was all pine, 2 x construction. Made a breadboard end on the tops but due to my inexperience with the construction, I ended up gluing the breadboard ends on the table. Less than 6 months later, the top split. Now, I'm not saying it was the glue up that caused it. The 2 x came from the local Blue Borg so the moisture content is suspect and I suppose there could have been other factors as well. Lew Kauffman-Wood Turners Forum HostTime Traveler and Purveyor of the Universe's Finest Custom Rolling Pins! Report
October 20, 201313 yr Author comment_8144 Hmmm now that's a definite possibility. The force of along-the-grain expansion in wood is rather considerable.Maybe the experts know sumpin' after all.The species of wood is of note. Some expand more than others though I must admit to failing at having an on-board catalog of which ones move more than others.I wonder if there's a forestry department document lurking on the interwebs somewhere on that topic. They published quite a substantial number of very informative documents some many years back. Though I fear, as of late, the pace of research and publication has diminished.I may know who to ask. Report
October 21, 201313 yr comment_8143 Excellent test and amazing results. Â Thanks Cliff for your work and reports.Fredaka Pop's Shopwww.pops-shop.com'Soooooo many patterns - sooooo little time'Scroll Saw Forum Host Report
October 21, 201313 yr comment_8142 Hey guys, drill a few holes in the board and drive a few hardwood dowels with glue on them ( make sure you slot the dowel first) and that will hold just fine.And cliff, next time please use pine for a test, I'd love some Siberian ANYTHING!!!!! Report
October 22, 201313 yr Author comment_8141 You want some? The stuff grows like weeds. It's a warm soft wood with lots of interesting grain. Turns buttery golden brown with a little BLO. Like soft cherry. Maybe a little softer.You can see it here:http://s1002.photobucket.com/user/zydaco/library/The%20Shop/A%20box?sort=3&page=1and herehttp://s1002.photobucket.com/user/zydaco/library/The%20Shop/more%20boxes?sort=3&page=1 I had them loaded to TPW but in a flurry of rules about having titles on images they got dumped. Report
October 24, 201313 yr comment_8139 Cross grain glue ups like in a mortice and tenon work because they are relatively short, even in a tenon it is prudent to leave some expansion room in the length of the mortice. On a wider tenon such as in a table with a breadboard end that is fully glued, the glue will hold the wood in place while the wider piece that has the tenon on it probably will shrink and expand with differences in seasons due to diffenent humidity levels. To test this do a breadboard end with pegged tenons and check it from the summer to winter, I would expect that the end piece will either be shorter or longer than the rest of the piece depending on the season. Report
