January 8, 201412 yr comment_6004 I have a Ryobi BT3000 Table Saw and lately it has become increasing difficult to raise the blade. its to the point where I have to use two hands and take 1/2 turn hard wrenches. any ideas whats causing it to act this way? Report
January 8, 201412 yr comment_6009 I'm assuming there is no lock on the handle Butch. Probably the lift assembly is packed with sawdust. A good lowing out with ye ole air hose should help the situation. I also read that that model has a lever that you have to disengage to switch back and forth between tilt and lift. Make sure that lever is fully shifted to the lift position.Ron DudelstonSite AdministratorAbove and Beyond WoodWorks Report
January 8, 201412 yr comment_6008 Is it also difficult to tilt the blade? Lew Kauffman-Wood Turners Forum HostTime Traveler and Purveyor of the Universe's Finest Custom Rolling Pins! Report
January 9, 201412 yr comment_6007 ButchDo you have the manual for this machine? If you do look on page 35. It shows the elevating screw assembly. I am assuming you have to release a cam and swing the lift handle to set it for a miter cut going by the drawing. I'm going to try and attach the manual in here. I have high lighted the areas on page 35 for you. I think Ron hit it on the head with needing a good cleaning and some lube. Hope this works for you.Wayne MahlerGod bless and protect our troops that serve so we can be free. Report
January 9, 201412 yr comment_6006 Good job Wayne! And thanks to the guys for a great answer to Butches issues!Wayne Mahler said: Butch Do you have the manual for this machine? If you do look on page 35. It shows the elevating screw assembly. I am assuming you have to release a cam and swing the lift handle to set it for a miter cut going by the drawing. I'm going to try and attach the manual in here. I have high lighted the areas on page 35 for you. I think Ron hit it on the head with needing a good cleaning and some lube. Hope this works for you. Wayne MahlerGod bless and protect our troops that serve so we can be free. John MorrisThe Patriot Woodworker Report
January 9, 201412 yr Author comment_6005 Thanks everyone (especially Wayne) for your help. I will get into it today or tomorrow and report back. Report
