Ron England Posted May 9, 2014 Report Posted May 9, 2014 ok i have been using my Freud router,and at first it was awsome to use,but now when i turn it on it dosent want to turn or i have to turn it by hand(finger)to get it started an then it is slow to start,then all the sudden it takes off like a scalded dog,an tryin to use the virable speed knob dosent work,so do i need to get a new one or is there some way to fix this one,any feed back is welcome take Life slowly,no reason to speed,it will be there when u get there,slow down an smell the trees an fresh cut wood
lew Posted May 9, 2014 Report Posted May 9, 2014 When you get it running, does the variable speed control have any effect at all? If not, it sounds like that might be the problem. Lew Kauffman-Wood Turners Forum HostTime Traveler and Purveyor of the Universe's Finest Custom Rolling Pins!
Wayne Posted May 9, 2014 Report Posted May 9, 2014 RonTry blowing it out with compressed air. If it has a lot of dust and stuff that can interfere with it. Can you turn the motor by hand easily? If you have access to the brushes look at them see if they are worn out and making good contact with the armature. If that don't help then I would have to go with what Lew said.Wayne MahlerGod bless and protect our troops that serve so we can be free.
Ron Dudelston Posted May 9, 2014 Report Posted May 9, 2014 Sounds like you have a dead spot in the commutator. I'm with Wayne, try blowing it out.Ron DudelstonSite AdministratorAbove and Beyond WoodWorks
Mark Wisecarver Posted May 9, 2014 Report Posted May 9, 2014 If it has brushes get in there and clean them real good.
Ron England Posted May 9, 2014 Author Report Posted May 9, 2014 thanks for thehelp guys i will try each one when i get back,goin to see my Dad this weekend an some other veterans at the nursinghome,they love it when i bring Jessejames(my service dog),he is the blond terrier in my pics,so i will keep yall informed on progress,oh an also got the addition all wired and now settin everything in place.take Life slowly,no reason to speed,it will be there when u get there,slow down an smell the trees an fresh cut wood
Ron England Posted May 14, 2014 Author Report Posted May 14, 2014 well,tried blowin it out seemed to work good then all the sudden it went wild,snaped my bit that was in it then just shut down,smelled alittle smoke,and it wouldnt turn at all,so i guess its time to buy a new one lol.take Life slowly,no reason to speed,it will be there when u get there,slow down an smell the trees an fresh cut wood
Ron Dudelston Posted May 14, 2014 Report Posted May 14, 2014 I thought I heard the sound of Taps playing.Ron DudelstonSite AdministratorAbove and Beyond WoodWorks
Cliff Posted May 16, 2014 Report Posted May 16, 2014 virable speed durn't woik and yous gots to start it with a pull cord? That's pretty bad.How old is this router?  I got a Crapsman that is better 'n 40 and it's virable speed and on switch work flawlessly. Too bad I can't stand the bearing howl it makes coz it's is so bad I never use the thing any moreI'm thinking that if you got yourself a brush kit ( they are cheap and easy to install) that your toy would run like new again.It might be necessary to re-cut the commutator - - another easy peasy trick - where you just take a small hack saw blade and re cut the grooves on the commutator. If you want thinner kerfs take the saw blade and run it flat against a grinder or abrasive belt to make it cut with no set to the teeth.  However when you inspect the commutator you'll know if it's OK by whether the grooves are pronounced or not.Loves me that virible speedThe bit about it coming on like gangbusters makes me wonder if there is a capacitor in the thing. Never have seen one in a router.Usually if you let the smoke out of them it's a problem coz gettin' it back in is way difficult.
Ron England Posted May 23, 2014 Author Report Posted May 23, 2014 well ordered new router from Sears,will pick it up on 29th,got the one w/the plunge an stationary.so soon to be creatin sawdust again,but need to make sure i wear long pants when usin yellowpine sense i am allergic to it lol,broke out around my ankles take Life slowly,no reason to speed,it will be there when u get there,slow down an smell the trees an fresh cut wood
