Making a Scrub Plane
INTRODUCTION
Years ago, a neighbor down the street gave me an old a Stanley “Defiance” No. 4 Smoother plane. Sort of forgotten about, it sat in a HD plastic bin in one of my base cabinets for 10 years. As this time went by, I have refurbished, made, and used many, many planes. Then just recently, I decided it would be nice to have a scrub plane. I was going to make one but wasn't entirely sure how much I'd use it so thought about converting a plane. One that I could use it as it was and then also as a scrub plane. This way I get the most out of it one way or the other. Thus...the refurbishing and conversion of this Stanley “Defiance” No. 4 Smoother plane into a Scrub Plane.
It was one rusty baby, which I cleaned up. I did an initial flattening of the sole and the sides.
Here it is after an initial cleaning.
I could make it into a scrub plane blade with a few modifications and use it like this but I didnt care for it. I felt it also needed re-japanning, re-finishing the knob and tote, cleaning all hardware and brass, etc., etc.
So the journey begins ......
Here's the plane's anatomy
BLADE MODIFICATION
I had another good #4 blade so used this plane's blade for making the cambered blade as required. It was in worse condition so it made sense for the modification.
With most scrub plane blades the cambered (curved cutting edge) is radiused between 3 – 10”. Lee Valley's is a 3” radius with a 30° bevel. It makes for a very, very aggressive cut. When you take a cut it removes alot real fast. After some thought and experimenting, I decided to use a 10” radius with a 25° bevel. This way if I want to keep changing the bevel in my pursuit of the optimum bevel, I'm losing little metal at a time.
Here's the blade's new cambered edge at 10” radius with a 25° bevel. The chip breaker is also attached. Its not needed and most scrub planes dont have one. However it's necessary for this build.
I slipped the blade into the plane and ran a test. I flattened a twisted 2 x 4 x 2 board in under 5 minutes. Boy! You lose a lot of meat quick!! I hogged off ¼” across the entire length.
MODIFYING THE MOUTH
After modifying the blade, I needed to modify the plane body's mouth some. That's why I modified the plane blade first. Even with Frog adjustment, this is almost always required. To determine how much to open the mouth you first set the plane blade and chip breaker assembly on the frog. When you get the protrusion of the blade's edge where you need it, you then can determine about how much to file the mouth opening.
I place a 6 inch rule on the frog and slide it to the opening to get an idea how much to file the mouth opening as seen here. So I needed about 1/16” removal.
It's best to do this in small increments leading up to it. Check, reassemble, check reassemble, file, refile, etc.
Re - Japaning the Plane Body and Frog
The next thing is stripping and re-japaning the plane's body. To do this, I remove all parts. I also remove all parts off the frog except the lateral adjustment lever.
The heavey duty stripper (seen in the photo) can be bought at Home Depot. It works quick. Under 10 mnutes.
I also flatten the frog's surface. I then strip, sand, and refinish the tote and knob as seen here.
I ran all the hardware and parts thru my make shift vibratory tumbler.
Here's the stipped body and frog.
Next, I mask out all metal areas with tape that won't see paint as shown here. Then I apply 3 coats of Dupli-color enamel engine paint. Each coat 10 minutes apart and under 1 hour as required. Here it is after 1st coat.
You can bake these parts in an oven at 200° F for a couple of hours (if you do it in your kitchen it smells and your wife will kill you), place directly in the sun with the temperature at least 65° F for all day (I've done this before. It works good), or let in sit in the house with inside temperature at least 65° F for a week.
Here's the re-japaned parts. There's a little rust on the end of the lateral adjustment lever as can be seen per the red arrow. This has been taken care of after removing all the masking tape.
After all is done the plane is re-assembled. There's still some minor work to be done but all in all it turned out well.
TESTING
So now I ran a test cutting some stock off a 2” x 4”
Here the blade is set to barely show. It's about 1/32” (.031”) out. It hogs off small shavings as shown.
Here the blade is set as far out as I can before the chip breaker shows. It's about 1/16” (.062”) out. It's hard to measure. It may be a little larger. It hogs off much larger shavings as shown. These shavings are quite thick. Better than a 1/16”.
With some fine tuning how the chip breaker sets in relation to the blade's cutting edge, you can adjust the minimum and maximum effective cutting range. You likely also will need to adjust frog position.
Thanks for looking!
Cheers!
MrRick
