November 3Nov 3 comment_382428 I am constructing my first rail and style door. Always before they were M & T doors. When you glue in the stile to the rail there is some end grain. Do you put glue sizing or glue on the end grain to seal it before you glue the door together?In my cases I am using a flat panel with space balls. Report
November 3Nov 3 comment_382429 I just put glue on both surfaces and clamp. Haven’t had any failures yet. Glues today are really strong even with end grain Report
November 4Nov 4 comment_382434 I always put glue on the tenon and mortise areas (green color). IMO, the shoulder and cheek areas (blue areas) are optional. When you slide the tenon into the mortise, glue will flow out of the mortise onto the cheek and shoulder areas and onto other areas that you do not what the glue to be. Danl Report
November 4Nov 4 comment_382436 In a recent presentation by Titebond's technical service manager he recommended one of two things:* apply some glue to the end grain and let it soak in for a few minutes, then add more and assemble the jointuse the Quick and Thick glueI've used the latter on many mitered picture frames and it's worked well for me.However, most of the strength will be on the faces of the tenon, but little more won't hurt. Report
November 4Nov 4 comment_382440 I just glue the cheeks and edges of the tenon. But with rail stile the tenons are fairly small, adding it to the end can't hurt. Edited November 4Nov 4 by Fred W. Hargis Jr Report
November 10Nov 10 Author comment_382617 On 11/3/2026 at 4:59 PM, Michael Thuman said:I am constructing my first rail and style door. Always before they were M & T doors. When you glue in the stile to the rail there is some end grain. Do you put glue sizing or glue on the end grain to seal it before you glue the door together?In my cases I am using a flat panel with space balls.I have a question on my rail and style door with space balls. The grove is 7/16 deep the space balls 3/16 so do I size my panel to slip into the 1/4" deep groove or should I counter sink the balls to both locate them securely and reduce their width. Just in general how much overlap from the panel into the S+R do you normally use? Report
November 10Nov 10 comment_382618 Well, for sure I wouldn't counter sink the space balls. I'd probably give the panel 5/16" (+/-) and let it squeeze the space balls a little. It needs to squeeze them a little since over time it's likely to shrink some, and you still wnat the space balls to keep it from rattling. Edited November 10Nov 10 by Fred W. Hargis Jr Report
November 10Nov 10 comment_382619 Google AI says:Use Space Balls in cabinet and furniture door construction to automatically center floating panels and allow room for seasonal wood expansion and contraction. Installation StepsPrepare the Panels: Sand the back side and routed edges of your raised panel before assembly, as these areas become inaccessible once the door is glued. Never apply glue to the panel itself; the panel must float freely inside the frame to prevent cracking or warping.Groove Sizing: Route the grooves in your stiles and rails deep enough to accommodate both the panel penetration and the spacer. For standard 1/4-inch space balls, a groove depth of roughly 7/16-inch is typical (allowing 1/4-inch for panel depth and 3/16-inch for the compressed spacer).Placement: Insert a minimum of 2 space balls per side (typically 8 to 10 space balls total per door)—placing a couple near each end of the rails and a couple in the grooves of the stiles.Compression: Space balls should fit snug rather than tight. When you clamp the door frame together, the space balls compress by roughly one-third of their diameter to hold the panel centered and eliminate rattling.Glue the Frame Only: Apply wood glue strictly to the cope-and-stick or Miter joints of the stiles and rails. Do not pin, nail, or glue the panel into the grooves. Report
November 10Nov 10 Author comment_382623 Thanks all is seems my R&S is made to work with the space balls. Thanks Keith and Fred for the quick replys I will do a final measurement again before glueing. Report
November 10Nov 10 comment_382629 If you have a floating panel, be sure to hold the glue back where the corners meet. If not any squeeze out will go into the groove and glue the panel in, and it's also a pain to clean up. DAMHIKT (Don't ask me how I know that). If you have a sheet good panel, it doesn't matter. In fact you can glue the panel in.Just a comment on space balls. Lot's of people use them, lot's of people think they are necessary but IME they are not. In fact, they add to the possibility of an error sizing a panel. A traditional way is to pin the center of the panel from the back so it will moved outward from the center. Personally I don't do anything b/c the amount of movement that may shift a panel off center is inconsequential. Some people use space balls to prevent rattle, which they will not always do. Rattle is caused by space between the groove and panel.I would defy anyone to tell whether any of these panels are not centered. 🙂Clamping up is a critical part of door making. Just enough pressure to close the joint, any more than that you risk warping the door. Check across the rails a straight edge to make sure the stiles are inline with the rails. Often times clamping will cause the stiles to tip. Either adjust the clamps, or place a caul across the joint (my choice).Nice flat doors make a project go much easier. Edited November 10Nov 10 by Robert Engel Report
November 11Nov 11 Author comment_382649 8 hours ago, Robert Engel said:If you have a floating panel, be sure to hold the glue back where the corners meet. If not any squeeze out will go into the groove and glue the panel in, and it's also a pain to clean up. DAMHIKT (Don't ask me how I know that). If you have a sheet good panel, it doesn't matter. In fact you can glue the panel in.Just a comment on space balls. Lot's of people use them, lot's of people think they are necessary but IME they are not. In fact, they add to the possibility of an error sizing a panel. A traditional way is to pin the center of the panel from the back so it will moved outward from the center. Personally I don't do anything b/c the amount of movement that may shift a panel off center is inconsequential. Some people use space balls to prevent rattle, which they will not always do. Rattle is caused by space between the groove and panel.I would defy anyone to tell whether any of these panels are not centered. 🙂Clamping up is a critical part of door making. Just enough pressure to close the joint, any more than that you risk warping the door. Check across the rails a straight edge to make sure the stiles are inline with the rails. Often times clamping will cause the stiles to tip. Either adjust the clamps, or place a caul across the joint (my choice).Thanks for the tips especially the corner issue. The stile and rail when under light pressure is closing the joint completely. Report
November 11Nov 11 comment_382662 13 hours ago, Michael Thuman said:Thanks for the tips especially the corner issue. The stile and rail when under light pressure is closing the joint completely.No problem good luck with your project! Report
