October 27Oct 27 comment_382213 Got a California Air Compressor at an auction. It had some sort of tire valve which leaked bad and since it went nowhere I capped it. Even before I capped that leak it would fill but when pressure goes down it will not restart to fill. I tried turning on and off plus pried unplugging. Opened the cover and increased the pressure screw and still no luck. I did notice that the fan tried to move and there was a small buss. I am thinking start capacitor. Can anyone give me ideas?? Report
October 27Oct 27 comment_382215 One thing to check is a "check valve" genreally on the top of the tank. One of the symptoms is what you are describing. It's worth a look. Report
October 27Oct 27 comment_382225 You say it will run but not hold pressure and then will not restart when the pressure is low?That sounds like the pressure control switch contacts might be sticking. If the motor start capacitor is bad, the motor would probably not run at all. The pressure switch is pretty easy to replace and most are available online Report
October 27Oct 27 Popular Post comment_382226 13 hours ago, Gerald said:California Air CompressorThat was your first mistake, nothing good comes from that Godforsaken state. Report
October 28Oct 28 Author comment_382231 Thanks y'all. I was looking for bright brass for the check valve and finally found it. It looked ok, the spring was not jambed together.When I first cranked it up it started fine. It holds pressure but does not kick on at 90psi like it is supposed to , There is a tube from the check valve to the pressure control switch, at the end of it is something like a tire valve and under that a small switch lever. This little deal was leaking air like no tomorrow. I removed that and placed a cap on the tube. Still has the same problem but that fixed a Grizzly many years ago. I can press that switch and contacts spark but does not start up. Found this pressurecontrol switch online in only two places.but cannot get that little valve by itself. So probably gonna cost another 50 to get it up working right.Hey funny thing the auction people gave me a propane tank and said it was an expansion tank, But it was not set up for that and I have not tested however think it is almost full of propane. Report
October 28Oct 28 comment_382233 I tried to use this video to repair my switch. I didn't have enough hands to do it but it does explain what the parts do- Report
October 28Oct 28 comment_382245 Something else I thought of was the unloader valve It takes pressure off of the compressor head so the motor doesn’t have to start against the built up tank/head pressure Report
October 30Oct 30 Author comment_382277 I was ready to replace the pressure switch but today went back and adjusted the max pressure screw which I found I had set wrong. After that it pumped up and stopped at 120. When I bled it down and it reached about 180 it gave a good attempt to start. Tried again and it would hum. The switch does spark when I turn off and try restart. Like Lew I had always thought bad start capacitor would not work at all. I did have a bad run capacitor on my generator and it was up and down. Report
October 31Oct 31 Author comment_382310 4610A_HOrdered the check valve. We will see. When I start it and after reaching 120 and stops I drain with drain valve instead of using the air gun. When the gauge reaches almost zero the motor kicks on and it pumps back up. After doing this and what I have learned I think the head pressure was up and not allowing start. We will see in a few days. Report
October 31Oct 31 comment_382330 Between that and the unloader valve are the only two things I can think of that cause the problem. Report
November 8Nov 8 Author Popular Post comment_382550 Got the check valve in and it was a booger to get the old one off and then to put new one on remembered a old small pipe wrench. This worked without marring the valve.The good news is it works. Report
November 8Nov 8 comment_382568 12 hours ago, Gerald said:The good news is it works.Awesome, Gerald!! Report
Friday at 05:26 PM1 day comment_382758 I'd definitely check the start capacitor, especially with the motor humming and the fan barely trying to turn. However, also check whether the compressor is holding pressure in the pump head or if the check valve or unloader valve is stuck. Report
