metamerism and color matching
Common Types of Metamerism
  • Illuminant Metamerism: A color match breaks down because the light source changes (e.g., car bumpers matching the body in a showroom, then looking different outside under the sun). [1, 2]
  • Observer Metamerism: Two samples match for one person, but look slightly different to another person due to individual differences in human color vision. [1, 2]
  • Geometric (Angle) Metamerism: A match changes depending on the angle at which you view or illuminate the object. [1]
  • Field-Size Metamerism: A match fails when the size of the color field in your field of vision changes (such as looking at a tiny dot versus a large painted wall)
Geometric metamerism is common in veneered table tops. If there are 4 parts in right angles to each other, from one direction, two will look darker and two lighter, rotate 90 degrees and they can all look the same, and another 90 degrees and the dark ones now look lighter and the lighter ones darker.
How does Chatoyance factor into this?
I'll guess it relates to "Illuminant Metamerism: A color match breaks down because the light source changes (e.g., car bumpers matching the body in a showroom, then looking different outside under the sun)."
Chatoyancy (or chatoyance), also known as the cat's-eye effect, is an optical phenomenon where a lustrous, three-dimensional band of light appears to glide or shift across a material's surface when the object, light source, or observer moves.
What Causes Chatoyancy?
  • Wood: Caused by rippled, wavy, or interlocked cellular configurations—such as in curly maple, koa, or mahogany—created by growth stress near branches and forks.
Where It Appears
  • Woodworking: Highlighted in instruments (like violin backs or guitar tops) and fine furniture using oil, shellac, or amber-toned finishes to make the grain "pop".
Edited by kmealy
If you are trying to color match two pieces of wood and one has high chatoyance and the other doesn't, how would that be compensated for?
Keep them in a dark room? 😁
Polyshades. * That will kill the chatoyance 😁
I am not sure there is a way to add chatoyance to a piece that does not have it.
* Steve Mickley used to call this "the worst thing to happen to a can." I've seen some pretty awful applications of it.
Yup. All you can do is mute the chatoyance on the part that has it, there is no adding it.
I worked with enough polyshades years ago to get good results, but what a pain it was. I could see using a finish like that in a production environment as a sprayed on finish applied by a practiced hand, but in a can it's a tough act to pull off well. And patching it is even more difficult than applying it!
A contractor brought me a hand rail, painted white, that was then covered with Polyshades. It looked like someone threw up all over it. I stripped and refinished, then they ghosted me. Should have gotten a deposit.
One of my regular customers, a furniture store with several locations, carried a lot of furniture with white or yellow paint and highlighted with glaze. I did a lot of repairs on it, but normally, you had to do a whole section as it was not possible to do just a spot repair.
