April 12Apr 12 Popular Post comment_374552 I'm calling this my Square Interlock corner joint, An alternative to half blind dovetails,Sample was cut from a pine panel scrap. Thus the variation in end grain showing. I've posted more photos, including of it with both sides before gluing and some renderings from Aspire onMy Blog Report
April 13Apr 13 comment_374553 That is one cool and unique looking joint. Undoubtedly a very strong joint. Thanks for sharing the idea and the end result. Report
April 14Apr 14 Author Popular Post comment_374659 I had to try one more variation. This one I call my Half Blind UpDn Diamond corner joint. Apart. Made this from oak and walnut for some contrast. Together. No glue yet. Fit required a 0.003 allowance on the oak side vector for a slip fit that doesn't require beating it in with a mallet. Time consuming to cut using a 1/8" end mill. Both boards are close to .72" thick. 4D Report
April 14Apr 14 Author Popular Post comment_374667 Glued Up. Sanded to 400 grit. One coat of Tung Oil only on the outer faces.UpDn Diamond Interlock Edited April 14Apr 14 by 4DThinker Report
April 15Apr 15 Author comment_374696 Finished my write-up about the UpDn Diamond Interlock here: My Blog4D Report
April 18Apr 18 comment_374896 You outdid yourself on this one 4D. A Gothic touch of elegance. Absolutely amazing! Report
