September 28, 20251 yr Popular Post comment_362399 This is a smoothing plane I made using hard rock maple. I used a Hock blade in it. Here's the blade poking out. I made this box for the plane. You just lift off the top. This reveals the plane sitting on the bottom ... .... Then just lift the plane off the bottom. As with any wooden plane you tap as required to adjust blade depth. This plane is beautiful for fine planing. You can go right to applying your finish after using it. Thanks for looking! " If you like it give it a 👍 " Cheers! MrRick Edited September 28, 20251 yr by MrRick Report
September 28, 20251 yr Author comment_362409 Thanks lew! Glad you like it. Cheers! Edited September 28, 20251 yr by MrRick Report
September 29, 20251 yr comment_362440 23 hours ago, MrRick said: I used a Hock blade in it. Beautiful plane Rick, another item on my todo list, still living my dreams through other peoples work 😃 Question, is Hock still producing irons? I thought he threw in the towel a while back? Report
September 29, 20251 yr Author comment_362443 After Ron Hock's retirement, his Hock Tools brand was acquired by Lee Valley Tools, ensuring the continued production and legacy of the blades, which are thicker, better finished, and offer a superior alternative to original equipment manufacturer (OEM) blades. Report
