June 11, 20251 yr Popular Post comment_357430 This was quite the project. Three panels out of 1 x 6 tongue and groove blue pine. Finished size 15 x 22 inches, laminated to a piece of 1/8" BB plywood. Top panel is a pattern of the Teton Range, which has special meaning for the newlyweds. Second panel is a silhouette of the couple, completely cut from the panel and stained black, then glued back in. The fancy horses, I cut the outside line then removed the horse so I could cut the fancy design inside the horse, stained the horses a little darker (used a charcoal pencil to shade the horses) then glued them back in. The third panel is "just" lettering, using a western font from dafont.com. The couple really like the piece. 15 hrs of cutting, but so worth it. Report
June 11, 20251 yr comment_357435 WOW! Nicely done Wichman. Good on you for such a personal gift. Report
