April 28, 20251 yr comment_355734 I'm making some 16" tall plastic laminate (formica) back splashes for the walls around my kitchen counters. I don't want to glue directly to the new sheetrock and mud joints. So I thought about srewing down 1/4" masonite as a substrate, then gluing the laminate to the masonite with contact cement. Would it be better to glue to the smooth side or the rough side? Report
April 28, 20251 yr comment_355736 You might consider a construction adhesive. Bothe LocTite and TiteBond make excellent products. Report
April 29, 20251 yr comment_355763 I've glued laminate with contact cement to particle board and plywood, but not masonite. Just a guess, but I'd think gluing to the smooth side would maximize the contact between the surfaces. Sounds like it's time for a couple of tests with some scraps, then you'll be the expert. Report
April 30, 20251 yr comment_355801 If you google "contact cement aging" there is a comment that the rubber is affected by time. If you only need the laminate to hold a couple years, the smooth side would do the trick. Longer term, I'd get "real" adhesive as Lew suggested. Edited April 30, 20251 yr by PeteM Report
May 1, 20251 yr comment_355848 FWIW, I've got a kitchen counter that was glued with contact cement 35 years ago and still hasn't let go. but yes, glue to the smooth side if the masonite. Report
