Popular Post kmealy Posted April 15 Popular Post Report Posted April 15 A good short article. Answer: it depends on what you are doing. My guideline has always been hip, navel, and nipple. Grandpadave52, Harry Brink, lew and 2 others 2 3 Quote
DAB Posted April 15 Report Posted April 15 mine are about 1" shorter than my TS height. that way, if needed, i can use them for infeed or outfeed support. kmealy, Grandpadave52, HARO50 and 1 other 4 Quote
Gerald Posted April 15 Report Posted April 15 Have to disagree with someone's idea on a lathe. Height should be that the spindle is approximately the height of your bended elbow. Otherwise I find this interesting to have it all in one place. lew, Grandpadave52 and HARO50 3 Quote
JWD Posted April 16 Report Posted April 16 I usually just make them 36" high as that is a comfortable general purpose height for me. I keep meaning to build a detail work riser like Steve Latta and others use, those are handy. First commercial shop I worked for had these, though without the vises and such that make them even handier. Funny that they have no hand tool examples HARO50 and Grandpadave52 2 Quote
kmealy Posted April 16 Author Report Posted April 16 On 4/15/2025 at 3:09 PM, DAB said: mine are about 1" shorter than my TS height. that way, if needed, i can use them for infeed or outfeed support. I did the reverse, I made the workbench to the appropriate height then raised my table saw up to meet it. When I use other table saws, they're always too low. But I'm a tall guy. HARO50, Gerald and Grandpadave52 3 Quote
DAB Posted April 16 Report Posted April 16 1 hour ago, kmealy said: I did the reverse, I made the workbench to the appropriate height then raised my table saw up to meet it. When I use other table saws, they're always too low. But I'm a tall guy. i'm 6-5, so above average height wise. i've just learned to bend over as needed to reach things made for shorter mortals. if i'm at my workbench and need to do fine work, i grab my stool and sit, thus getting closer to the work bench and what is on it. my DeWalt TS didn't really have a height adjustment available. you could level the feet to fit an uneven floor, but no +/- 4" or so. i do have one work bench that is taller, but i rarely use it for work, as it's full of scraps and stuff and 2 large vises. Headhunter, HARO50, Grandpadave52 and 1 other 4 Quote
DAB Posted April 16 Report Posted April 16 was just down in the shop, cleaning up my TS a bit, so i measured its height: 34-1/2" above floor. now you know. Gerald, Grandpadave52 and HARO50 3 Quote
Ron Dudelston Posted April 16 Report Posted April 16 I’m the odd duck out here. I have an assembly table on wheels that I use. Without measuring it, I would put the height at about 30 inches. However my actual bench is much taller. Fred W. Hargis Jr, HARO50, Grandpadave52 and 1 other 4 Quote
kmealy Posted April 17 Author Report Posted April 17 When I made my bench from a Tage Frid plan, I used the guideline to make the top even with your palms flat and at your side. Once I got ready to assemble, I realized there was an error in the plan. Fortunately, it just meant cutting some new tenons in the top of the legs. Then I realized why the bench I'd been using, one that I inherited when a prior apartment tenant left it, always gave me a back ache. It was way too short. HARO50, Gerald and Grandpadave52 3 Quote
