Posted (edited)
These are not single units , but custom fit units.. you may or may not have toe boards. These units have them built in.. Cabinet installation is roughly 10 minutes per thousand. You can do the math..
Edited by BillyJack
Posted (edited)
This is Russel. Russel was my helper for several years. Russel was a Baptist minister searching for a church. He could not minister his own church..
Edited by BillyJack
Posted
 I'm a little confused, per thousand dollars?
Posted
84" is the standard height to the top of 30" high wall cabinets.  The 36" and 42" high have become more popular if the ceiling height allows.  I've always been a fan of ledger strips leveled at 54" from the highest point of the floor.  Then it doesn't matter what height wall cabinets are used in the design.
  • Like 2
Posted
If a set cost $4,000 I was expected to install in 1 hr. That’s off the truck  and sitting in place.
  • Thanks 2
Posted
What influences this set is the pantry.
Posted
I can do the math: image.png.1faad3354b3d76287f1be586c3cf682b.png
Posted
It will keep the man happy.
Posted (edited)
Russel is now marking first studs..
Edited by BillyJack
Posted
Many cabinet manufacturers have starting points with their cabinets. We don’t always like to start that way, but it’s requires to install..
Posted (edited)
We know the floor is pretty level going towards the pantry..
Edited by BillyJack
Posted
When your using sticks like this, all the weight is being carried by the sticks while you level.. I prefer this method of cabinetry over individual boxes.
Posted (edited)
This is my personal preference with installation. I have found mounting and leveling the uppers has always worked well. I prefer the toe boards attached.
We use cabinet installation screws from suppliers . These are not where we buy these , but are similiar.
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.amazon.com%2FSaberdrive-Cabinet-Screws-Approx-Pieces%2Fdp%2FB08PMKH7TN&psig=AOvVaw1oHXW0nZeowEFuA3ZYnT13&ust=1742062512500000&source=images&cd=vfe&opi=89978449&ved=0CBcQjhxqFwoTCPj4z96WiowDFQAAAAAdAAAAABAJ
Edited by BillyJack
  Only 75 emoji are allowed.
