March 4, 20251 yr Popular Post comment_353062 Many of you may know that my table saw is a 1947 right tilt Unisaw. A few weeks ago it refused to start up so I tapped the motor with a hammer and it took off. I figured it was probably time to do a little maintenance on the bullet motor. These motors are a beast weighing in an about 90 pounds and are a real pain to pull out and rebuild on a bench so I opted to rebuild the back end on the machine. After a ton of research on OWWM and our own Larry Buskirk I ordered bearings, brushes and a spring for the “necklace”. This motor was built before capacitors and is an induction reversing motor. I won’t bore you with the details on IR technology but it uses a spring loaded centrifugal copper necklace. Anyway, I thought I had everything I needed but the Amazon supplier send arbor bearings instead of motor bearings so I ordered the rear bearing from MRO Supplies. Mistake there because they still haven’t shipped them so I ordered one from eBay. The bearing is a bit of an oddball and a little hard to find. Anyway, today, I cleaned the commutator and reassembled the motor. It runs great and I almost feel accomplished. Report
March 5, 20251 yr Popular Post comment_353071 Good day Ron. Glad it all worked out and you didn't have to get a bigger hammer. Edited March 5, 20251 yr by Grandpadave52 Report
March 5, 20251 yr Author Popular Post comment_353076 1 hour ago, Grandpadave52 said: Good day Ron. Glad it all worked out and you didn't have to get a bigger hammer. The brushes were down to a “nubbin” Report
March 5, 20251 yr Popular Post comment_353077 Just now, Ron Dudelston said: The brushes were down to a “nubbin” Your saw is five years older than me. I'm already down to nubbins myself. Report
March 5, 20251 yr Popular Post comment_353083 Well it is the same age as me and if it is creaking like I am , it ain't good Report
March 6, 20251 yr comment_353188 I ditched my old RI motor around 2012 I think..... I almost went this route instead, but I needed the saw working ASAP so I got a replacement Leeson. Felt kinda bad junking the old RI motor, as it was pretty, but I do like the speed of the modern motor better. Last time I had to replace bearings of that kind of vintage was just this year in a motor for a Monarch lathe at work. The bearings in it were made by Hoover and had last been replaced in the 1960's (lathe is WWII vintage, a tech from the USN had written the replacement date on the motor). I took one apart, and all that was wrong with it was the grease had lost its oil. Those were a little hard to find too, we got some NOS bearings from ebay, but next time around I doubt that will happen. Bearings have been standardized to metric for so long now, no one makes older sizing standards as far as I know. Edited March 6, 20251 yr by JWD Report
