November 1, 20242 yr Popular Post comment_345392 Good morning. I know I haven’t been on here a lot lately but life crazy busy for the most part in a good way. My Ridgid oscillating belt, even after replacing, will not stay in place. As it rises the belt slides down. I have tried to tighten and loosen the tension. Is there another adjustment I am missing? thanks friends Report
November 1, 20242 yr Popular Post comment_345395 With mine, I just fiddle with the adjuster knob in, small increments, until the belt stays put. If you don't use a vac during operation, accumulated dust may be the culprit. At any rate, try blowing it all out while it's runinng without a belt. Report
November 1, 20242 yr Popular Post comment_345398 Once the tension is set the adjuster keeps it centered. Report
November 1, 20242 yr Popular Post comment_345420 If you remove the sander from the spindle, and like Gene stated you can clear out any dust & debris in and under the sander. Give all the moving parts a little blast of teflon spray. Report
November 3, 20242 yr Author Popular Post comment_345513 Thank you guys Your suggestions work! I appreciate y’all! Report
