Posted
I've lost track of which sides my cutters are on.
I do the same thing with my EWT's.
  • Like 3
Posted (edited)
If you (or he) has one similar to THESE I'd give it a try. Mine is a 40+ year old Mac Tool version. It's always my go to tool for breaking loose stuck fasteners if I have access. Works on the same principle Ron describes using a steel or brass drift on the head but transfers the force directly to the bolt. Mine has a 3/8" square drive so most standard or impact sockets or bits can be used or an adapter. I used it for years primarily to remove the field coil winding retaining bolts on HD starters & generators but for countless other applications too.
Sorry imbedding the link function doesn't seem to be working now; copy and paste below.
https://www.amazon.com/KAIFNT-Manual-Impact-Driver-24-Piece/dp/B08LYSHNCW/ref=pd_lpo_sccl_3/145-0090060-5680664?pd_rd_w=ulGlI&content-id=amzn1.sym.1ad2066f-97d2-4731-9356-36b3edf1ae04&pf_rd_p=1ad2066f-97d2-4731-9356-36b3edf1ae04&pf_rd_r=2X07Q9A37MG7NVE93TDQ&pd_rd_wg=sBHw9&pd_rd_r=6febc915-58b0-499d-9414-e6437949b8c0&pd_rd_i=B08LYSHNCW&psc=1
Edited by Grandpadave52
  • Like 2
Posted
I also have one of those things Dave to which Dave referred, mine isn't a MAC (wish it was) but a Lisle. They really do work well.
  • Like 3
Posted
I'm not so sure that Lisle may have made the one for MAC Tools way back in the day Fred. Lisle did and does make numerous automotive specialty tools. All good quality. In fact, the MAC tool rep I had those many years ago was also a Lisle distributor.
Posted
+1 for Dave's tool of choice.  Mine has seen a lot of use over the years.
I could see where planing pine would cause future problems with the screws being stuck, not so much hardwood.  Would this be an application where you might try a thin wipe of anti-seize on the threads when doing the install?
  • Like 4
Posted
5 hours ago, Cal said:
would this be an application where you might try a thin wipe of anti-seize on the threads when doing the install?
IMO Cal, I wouldn't advise it. Using anti-sieze reduces the coefficient of friction which will lead to incorrect torque being applied. Not an application to have incorrect clamp load on the joint.
Likely the problem is being encountered underneath the bolt head (assume it's a tapered or countersink head bolt?) and the mating countersink of the cutter insert. The difference of materials (carbide cutter insert & hardened steel bolt) along with heat transfer will "bond" the two as really it should. The hand operated hammer impact releases that "bond."
I also fully agree with Fred to be sure to hand-torque each one to the manufacturers spec using a torque wrench. Over torquing potentially can stress the carbide causing small facture lines ultimately leading to failure. Severe enough over torque may cause the fastener to stretch beyond it's elastic state leading to loosening or breakage. Under torquing can result in UFOs (Unwanted Flying Objects).
Proper cleaning of an insert and the mating insert bed is critical too.
I'm probably being over cautious, but I've seen cutter & fastener failures in manufacturing. It ain't pretty.
  Only 75 emoji are allowed.
