Popular Post KevTN Posted February 10, 2024 Popular Post Report Posted February 10, 2024 Here is the new Onefinity Woodworker Elite and my first three projects. Cutting board on a CNC? It is how I flattened it after glue up it was too big for the planer; besides we all know that running end grain will explode when ran through a planer…. Works great! The second is a cheese board I threw the design together. Both made out of Bacon Paduk. The fishing one is a ‘rough draft’ on a scrape pine. Cal, honesttjohn, difalkner and 3 others 5 1 Quote
4DThinker Posted February 10, 2024 Report Posted February 10, 2024 The bleeding into the grain on the hunting sign can be reduced if you carve, then spray/brush on some sanding sealer before painting the carved letters/images. Otherwise I like the sign, and it appears you've got a good setup for that CNC. Cal, Grandpadave52 and difalkner 3 Quote
Grandpadave52 Posted February 10, 2024 Report Posted February 10, 2024 Looks like all systems are a go Kevin. Excellent work. Looking forward to following your creativity with the new machine. Cal 1 Quote
KevTN Posted February 10, 2024 Author Report Posted February 10, 2024 3 hours ago, 4DThinker said: The bleeding into the grain on the hunting sign can be reduced if you carve, then spray/brush on some sanding sealer before painting the carved letters/images. Otherwise I like the sign, and it appears you've got a good setup for that CNC. Yeah I did seal it with with shellac even the the shellac bled lol. honesttjohn, Grandpadave52 and Cal 3 Quote
KevTN Posted February 10, 2024 Author Report Posted February 10, 2024 1 hour ago, Grandpadave52 said: Looks like all systems are a go Kevin. Excellent work. Looking forward to following your creativity with the new machine. Thank you. It def is a learning curve, nice to know that I don’t have to worry about what my machine is going to do. honesttjohn, Cal and Grandpadave52 3 Quote
