John Morris Posted September 2, 2023 Report Posted September 2, 2023 "What's It" Basic Rules Reminder For a full run down on this project and rules please go to: "The Patriot Woodworker and MWTCA "What's It" project" Only Patriot Woodworker Members are eligible to participate and receive the award. The MWTCA only accepts a verified source to support your answer, so one should be submitted with your answer, such as a patent, catalog entry, tool book reference, or a respectable website on the subject. Do not let these requirements prevent you from having fun and submitting educated answers on the subject without verification, we can worry about references later. All answers are welcome, as well as healthy debates regarding "What's It". If a verified and referenced answer is not arrived at by the end of each month's "What's It" project, a random draw will be performed for a "One Year MWTCA Club Membership". Only Patriot Woodworker's who participate in this "What's It" topic will be included in the random draw. Additional What's It Rules Unless you are completely sure what this item is, please avoid "definitive statements" that appear that you are without a doubt claiming that you know what the item is. For example stating, "this item is called a "widget xx" used for "insert purpose here". If you are making a definitive statement you must accompany your statement with evidence or proof from a secondary source. An example of acceptable statements within the realm of having fun and educated guesses would be something like this, "I believe it could be", or "It appears it's made for this or that", etc etc etc... Ok ladies and gentlemen, we now have our "What's it" live and ready! The image(s) below is a MWTCA "What's It" image for you to research, and tell us all here in this topic post, just what the heck is it! Project Details The information provided hereon is all the information that is provided, no further information on this item will be added. Cal, steven newman and HARO50 1 2 Quote
Popular Post Grandpadave52 Posted September 2, 2023 Popular Post Report Posted September 2, 2023 Ninja Warrior belt buckle Cal, Larry Buskirk, HARO50 and 2 others 1 4 Quote
Popular Post John Morris Posted September 2, 2023 Author Popular Post Report Posted September 2, 2023 Hmmm, I wonder. If you look at the last image.The semi pointed tooling, almost resembles a lettering stamp, we use them at our job to punch text onto metal surfaces, such as brass and aluminum. The lettering punches are straight though, and tiny. But it got me to thinking, that the semi pointed tooling can be interchanged with others, and perhaps have a different strike pattern. So, bare with me. The item with the two rods, looks like an adjustable fence. And the main brass body looks like it was made for striking with a mallet? So you could set the fence and let it guide the stamping along a straight edge that you'd be working on, meanwhile interchanging the stamped tooling. And what you'd have is a nice straight stamped line of whatever it is your stamping. Hey, it's a start! Larry Buskirk, HARO50, Grandpadave52 and 2 others 5 Quote
Popular Post John Morris Posted September 2, 2023 Author Popular Post Report Posted September 2, 2023 Actually, never mind all that BS above, after looking at it that would be an impossible task, with the pointy thing sticking out as far as it does. WELP, back to the drawing board. steven newman, HARO50, Headhunter and 3 others 1 5 Quote
Popular Post HandyDan Posted September 2, 2023 Popular Post Report Posted September 2, 2023 1 hour ago, John Morris said: And what you'd have is a nice straight stamped line of whatever it is your stamping. Leather belt comes to mind. Grandpadave52, Larry Buskirk, HARO50 and 2 others 5 Quote
Popular Post HandyDan Posted September 2, 2023 Popular Post Report Posted September 2, 2023 (edited) All I could come up with is the thought that it designed as a burnisher. The distance of the fence would help with angle control. Edited September 2, 2023 by HandyDan FrederickH, Larry Buskirk, John Morris and 4 others 7 Quote
Popular Post John Morris Posted September 2, 2023 Author Popular Post Report Posted September 2, 2023 3 minutes ago, HandyDan said: All I could come up with is the thought that it designed as a burnisher. The distance of the fence would with angle control. That crossed my mind too Dan! HandyDan, Grandpadave52, Cal and 3 others 6 Quote
Popular Post Ron Dudelston Posted September 2, 2023 Popular Post Report Posted September 2, 2023 I’m guessing some sort of marking gauge. There are two moving parts. The slide with the two pins has a boss on it and the tapered piece also slides. The pinned slide does the clamping and the tapered piece locks it in place? Cal, Larry Buskirk, Grandpadave52 and 3 others 6 Quote
Gerald Posted September 2, 2023 Report Posted September 2, 2023 I do not see any damage on the brass so I think a piece is missing which the brass mounts into. Note the flat area with a rise in front. Now that wavy fence could go into an opposite wave . Also note that shelf above the spike. I think the spike is designed to go into a hole like a place marker. Cal, HARO50, Grandpadave52 and 1 other 4 Quote
steven newman Posted September 6, 2023 Report Posted September 6, 2023 (edited) I am looking more at the Coat of Arms.....this tool is English made... Also...the 4 "corners of the "spike" are different from each other... Another curious item? Set screws on the sides of the Brass ...? There also seems to be numbers on that flat section...Model Number? Whatever they were pulling through this JIG,,,maybe to add a "lip" to an edge? Pull through once, rotate to the next size "detail", pull again...rinse and repeat for all the corners...The fence would be adjusted as you went....to get the right amount of "curl" to the edge... Just a WAG.... Edited September 6, 2023 by steven newman Brain started working John Morris, Cal, Grandpadave52 and 1 other 3 1 Quote
steven newman Posted September 19, 2023 Report Posted September 19, 2023 Thinking this MIGHT be a jig for either a Tinsmith or a Silversmith.... That square block could also have been changed out to a round ( Hollow) profile? The "spike" could also be used as an Anvil..... The "notches" in the fence MIGHT have been use to guide Punches..... Cal, Grandpadave52 and John Morris 3 Quote
steven newman Posted October 9, 2023 Report Posted October 9, 2023 So...now that it IS October.....what was that tool? Grandpadave52 1 Quote
