June 3, 20233 yr Popular Post comment_315440 A few more pics of the Mission style bed build. Danl When I sawed the Head and Foot board rail checks, I used my TS tenoning jig. The boards cleared the ceiling by ½.” I used my TS with a flat bottom blade to make the tenon shoulders. I decided to have two tenons for the wider rails instead on one. I used a jig saw and a chisel. Trial dry fit. I made (4) corbels and used a routing template to help clean-up the rounded profile. I will use splines to help attach the corbels to the bed legs. The bed spindle are located by using spindle strips. The strips were match made using a dado stack on the TS. A few more dry fit pics. The footboard was done the same processes. Report
June 3, 20233 yr comment_315459 Not sure if that's a King or Queen but I hope you have plenty of help carrying it to it's resting place.....that is one sweet bed! Report
June 3, 20233 yr Author comment_315461 38 minutes ago, sreilly24590 said: Not sure if that's a King or Queen but I hope you have plenty of help carrying it to it's resting place.....that is one sweet bed! It is a queen size bed. I just hope the box springs fits inside of the rails. I could not find any plans that were for a queen size using a box spring. So, I used my best guess. Yes, it will be heavy. Thanks Danl Report
June 5, 20233 yr comment_315527 Thanks Dan for the pics, tips and taking us along. Awesome craftsmanship going into this build. Report
