May 11, 20233 yr Popular Post comment_314122 So..which of these has the better claw? Both are 16oz Claw Hammers...but...one is a bit...different.. Wonder which will work better, in case I have to pull a bent nail, someday... Report
May 12, 20233 yr Popular Post comment_314130 I'm picking the one on the right! The left one looks like an old "Plumb" that I have. Report
May 12, 20233 yr Popular Post comment_314138 the one on the right has more "curve" to it. But isn't the "correct" way to remove a nail with a hammer to lever the nail sideways and not by prying the nail backward toward the head of the hammer? Somewhere back in the recesses of my mind, I tend to remember that. NOT saying that's how I do it. If you're using a cat's paw or crowbar all bets are off! Edited May 12, 20233 yr by smitty10101 Report
May 12, 20233 yr Popular Post comment_314140 When pulling by the head of the head of the nail the right one will give you more leverage, the left one will pull a longer nail. Report
May 12, 20233 yr Author comment_314165 IF one is levering a hammer side-to-side to pull a nail..... you have a Rip Claw Hammer...and you are fired.....Curved Claws , (place a bit of scrap on the surface if you don't want things marred up) get the claw under the head of the nail,,,and simply pull back towards you. Simple as can be... Rip Claw Hammers are more for doing just that..ripping things apart...Sharpen the tips of a rip claw...so that if you are sliding off of a roof, slam the claws into the sheathing to stop your slide. Report
May 13, 20233 yr Popular Post comment_314193 7 hours ago, steven newman said: slam the claws into the sheathing to stop your slide. Then go clean your underwear??? Report
May 13, 20233 yr Author Popular Post comment_314194 I went looking through the shop...could not find a single Rip claw hammer... However...lookee what I found in the Tool Cabinet... A 20oz Estwing....amongst a few others.. Report
May 15, 20233 yr Popular Post comment_314373 On 5/12/2023 at 1:14 PM, steven newman said: Rip Claw Hammers are more for doing just that..ripping things apart...Sharpen the tips of a rip claw...so that if you are sliding off of a roof, slam the claws into the sheathing to stop your slide. Probably less painfull than using the nail gun to stop the slide. DAMHIKT Report
