May 21, 20224 yr comment_291330 CARPENTER BEES ARE YOU PLAGUED WITH THEM? THEY CAN LITERALLY KNOCK A BUILDING DOWN IN A MATTER OF YEARS. I think I have the nuclear bomb, the bee doomsday device. Bayer Bioadvanced Carpenter Ant and Termite I have found one thing that kills them. Not some stupid trap, not some stupid air projectile, but kill them En MASSE Bayer Bio Advanced Carpenter Ant and Termite. You need a good sprayer. I like the SOLO 430-2G Handheld Sprayer Farm & Landscape, 2-Gallon, White, for around $40 on amazon. For my money, it is the single best sprayer in so many ways. Plus all the parts are replaceable, so you will keep it for decades. Mix it as per directions 1/4 cup per gallon. CYFLUTHRIN is the agent in it that kills bugs. It won't hurt you or your pets. It is a Pyrethrin derivative. Pyrethrin comes from a Chyrsanthemum. The way it kills insects is VIA their Sulfur Synapse. Mammals don't have a sulfur synapse. Spray it all over your house's eaves, all exposed painted and unpainted woodwork around the base of the building, essentially anywhere you see ants or other bugs who are unwelcome. No need to keep the surfaces wet. The Carpenter bee lands on your woodwork the feet pick up the agent even if it's been a couple days since you sprayed and the bee is dead in a few hours. Ya gotta be merciless. Spray it on all wood surfaces. https://www.amazon.com/Solo-430-2G-2-Gallon-Multiple-Spraying/dp/B000HHO8IG/ref=sr_1_1?keywords=solo+pump+sprayer&qid=1653173543&sr=8-1 https://www.amazon.com/BioAdvanced-Carpenter-Pesticide-Outdoors-Concentrate/dp/B09Z9H371V/ref=sr_1_2?crid=3PW8DQL9RQS2I&keywords=bioadvanced+carpenter+ant+%26+termite+killer+plus+concentrate&qid=1653173734&s=lawn-garden&sprefix=bio+advanced+carpenter+ant+%26+termite+killer+plus+concentrate%2Clawngarden%2C104&sr=1-2 Report
May 22, 20224 yr comment_291333 Thanks! Doesn’t sound nearly as much fun as that long range spray for wasps and yellow jackets. Report
May 22, 20224 yr comment_291378 I use a tennis racket. They sure did a number on my patio enclosure. Danl Report
