April 26, 20224 yr comment_289365 how do I replace the tape in a stanley? tape measure? Thanks Preston Report
April 28, 20224 yr Popular Post comment_289505 On 4/26/2022 at 11:34 AM, steamshovel said: how do I replace the tape in a stanley? tape measure? Lend it to someone who loses tools and then tell them to buy you a new one? All my Craftsman tapes had lifetime warranties but they are slowly being swapped out as the replacement is made in a Stanley w/ one year warranty IIRC. Personally, I'd buy half a dozen STANLEY 12 ft Tape Measure, 3/4 in Blade Mfr #: 33-312 from Zoro for $42.30 delivered, mark them with an ink pen, and never lend them to anyone. Just like I keep a credit card with LOW limit handy, in case a black sheep relative wants bail money, I keep a junk tape handy for the 'borrowers' who do not warrant quality tools. I know this does not answer your exact question; but after working in the trades for years with zero employees but constantly around others, habits developed. Report
April 28, 20224 yr Popular Post comment_289522 Luckily, with the shop construction done, I've semi retired my tapes. Most of the measuring for machine set ups is now accomplished with1,2,3 blocks and a graduated set of keyway stock. If they can't get me close enough, feeler guages or playing cards work. A little Stanley 12' tape rests near the miter saw, though. My brain and eyes find reading a tape tedious. They're not all that accurate, either. I've never done the comparison test among tapes. I just assume that none will agree. So why bother? Report
April 28, 20224 yr Popular Post comment_289523 Check at the local Borg for the schedule of the Stanley/Bostitch tool rep visit. They give their tapes away as promotions. Report
April 30, 20224 yr comment_289694 On 4/26/2022 at 10:34 AM, steamshovel said: how do I replace the tape in a stanley? tape measure? Pull the old tape all the way out. It will have a triangular slot (hole?) at the end, with the spring coming up through it. While holding the spring, remove the old tape and, while holding the new tape in its curled position, slip the end of the replacement tape over the spring, turning it so that the "T" shape on the spring holds the tape. Slowly let the tape unwind, retracting into the case. Trust me, I've replaced dozens of them. Okay, it just occurred to me that your tape may be broken off at some point, which would necessitate opening the case, rewinding the spring, THEN replacing the tape as described. Edited April 30, 20224 yr by HARO50 Report
