Popular Post Ron Altier Posted January 26, 2021 Popular Post Report Posted January 26, 2021 A few years ago I posted that I was having a lot of problems with my phone. It would not charge. Before I took it in to be repaired, I looked in the plugin receptacle in the phone because it looked too light colored. I discovered it to be packed with sawdust. (I usually kept my phone in my shirt pocket, for easy access.) A quick blow out and problem solved. Two phones later, I have the same problem, the phone won't charge. A quick look showed nothing. I thought a closer look may help. I got a magnifying glass and a bright light. That revealed a very small piece of sawdust. A quick blowout with electronic spray and problem solved. Don't use blow air that may contain moisture or any other contamination. Gunny, HARO50, Cal and 3 others 5 1 Quote
Popular Post DAB Posted January 26, 2021 Popular Post Report Posted January 26, 2021 sawdust and outlets don't mix. DuckSoup, Cal, Gunny and 2 others 5 Quote
Popular Post lew Posted January 26, 2021 Popular Post Report Posted January 26, 2021 When I got my new phone, it came with a charging cradle that doesn't require an electrical wire to the phone. Just set the phone on the device and it charges wirelessly. Love it! HARO50, FlGatorwood, Harry Brink and 4 others 6 1 Quote
Popular Post Gunny Posted January 26, 2021 Popular Post Report Posted January 26, 2021 34 minutes ago, lew said: When I got my new phone, it came with a charging cradle that doesn't require an electrical wire to the phone. Just set the phone on the device and it charges wirelessly. Love it! I am guessing it wasn't the $30 versions I get. FlGatorwood, lew, Artie and 8 others 11 Quote
Popular Post lew Posted January 26, 2021 Popular Post Report Posted January 26, 2021 No, I wish it was. I need a phone that I can use with hearing aids. When I got the hearing devices, the only phone that was available for that was an iPhone. Fortunately the lesser expensive ones work for me Gene Howe, Gunny, Cal and 5 others 8 Quote
Popular Post Larry Buskirk Posted January 26, 2021 Popular Post Report Posted January 26, 2021 Sure they do, take one smart phone and use a Louisville Slugger on it. FlGatorwood, p_toad, Gunny and 5 others 8 Quote
AndrewB Posted January 26, 2021 Report Posted January 26, 2021 Been there done that several times already. Simple answer to this is you've some how managed to get sawdust in the charging port of your phone and the power connection cable is not making the proper connection to charge the phone. The simplest fix for that is to basically take a can of air and blow out the charging port. It works for me every single time. p_toad, Cal, FlGatorwood and 1 other 4 Quote
Popular Post Ron Altier Posted January 27, 2021 Author Popular Post Report Posted January 27, 2021 4 hours ago, lew said: When I got my new phone, it came with a charging cradle that doesn't require an electrical wire to the phone. Just set the phone on the device and it charges wirelessly. Love it! My phone was a gift from my daughter and included a wireless charger. It worked great..................for a week. It failed to work after that, so I just started plugging it in. The wireless charger is a Samsung and the phone is an iphone, so there may be a mismatch FlGatorwood, Gene Howe, Cal and 3 others 6 Quote
Popular Post AndrewB Posted January 27, 2021 Popular Post Report Posted January 27, 2021 I don't know about the samsungs but but the connection just may be bad also you could look up both of the numbers for the phone and the charger and make sure its the right charger for the right phone from what I know and I phone charging pad wont work for a samsung charging pad. I have a charging pad for my iphone since I've recently switched. p_toad, FlGatorwood, Cal and 2 others 5 Quote
lew Posted January 27, 2021 Report Posted January 27, 2021 58 minutes ago, Ron Altier said: The wireless charger is a Samsung and the phone is an iphone, so there may be a mismatch That’s what I have too. So far so good Artie, p_toad, Cal and 1 other 4 Quote
Popular Post Masonsailor Posted January 27, 2021 Popular Post Report Posted January 27, 2021 I have an iPhone and had the same problem with it packing full of sawdust. I recently had to get a new iPhone and at the store they had a pelican case that has a snap cover for the charging port. Have not had the problem since and am happy with the case. Paul p_toad, HARO50, Artie and 3 others 6 Quote
Popular Post Gene Howe Posted February 2, 2021 Popular Post Report Posted February 2, 2021 I solved the phone vs. saw dust problem. I don't carry the phone to the shop, any more. The damned thing's ring startled me in the middle of a tricky table saw cut. Disaster averted but, a lesson learned. Add the phone to long hair, long sleeves, jewelry and alcohol as things banned from the shop. Artie, HARO50, FlGatorwood and 5 others 8 Quote
Popular Post AndrewB Posted February 2, 2021 Popular Post Report Posted February 2, 2021 Oh I always have my phone on me what happens if I wind up getting injured to badly to take care of it myself Id have to call an whambulance to my house. So I just have a habbit of carrying mine on me constantly. Cal, Artie, FlGatorwood and 3 others 6 Quote
Popular Post Gunny Posted February 2, 2021 Popular Post Report Posted February 2, 2021 1 hour ago, Gene Howe said: I solved the phone vs. saw dust problem. I don't carry the phone to the shop, any more. The damned thing's ring startled me in the middle of a tricky table saw cut. Disaster averted but, a lesson learned. Add the phone to long hair, long sleeves, jewelry and alcohol as things banned from the shop. I'm with you. Being in the shop is time away from people. If it's important my wife will bring me some tea and let me know. If it's ex wife then my wife will just ignore and forger about it. Just another sales call. p_toad, Gene Howe, Fred W. Hargis Jr and 5 others 8 Quote
Popular Post Ron Altier Posted February 3, 2021 Author Popular Post Report Posted February 3, 2021 When I lived in Ohio, mushroom hunting was a big thing. The guys I worked with had their secret places and always seemed to get a lot of them. One old guy told me that he had been getting them for most of 40 years. He said the last time out he had walked about a mile and realized he left his cell phone in the truck and was so uncomfortable, he went back to get it. He couldn't figure it out, he had hunted mushrooms for more than 35 years without a phone and now couldn't go a half mile without it HARO50, Gerald, FlGatorwood and 5 others 2 6 Quote
Popular Post Ron Altier Posted February 3, 2021 Author Popular Post Report Posted February 3, 2021 On 1/26/2021 at 12:40 PM, lew said: When I got my new phone, it came with a charging cradle that doesn't require an electrical wire to the phone. Just set the phone on the device and it charges wirelessly. Love it! I just received a wireless charging station from Amazon and it is working great. It will charge 2 phones at the same time. Cost $10 delivered to my door in 2 days. It didn't have a USB or cord, but the old one worked just fine and I am pleased. p_toad, Gunny, Cal and 2 others 5 Quote
Cal Posted February 3, 2021 Report Posted February 3, 2021 11 hours ago, Ron Altier said: I just received a wireless charging station from Amazon and it is working great. It will charge 2 phones at the same time. Cost $10 delivered to my door in 2 days. It didn't have a USB or cord, but the old one worked just fine and I am pleased. It came without the needed cords? Glad you had some that worked with it. Gunny, p_toad, DuckSoup and 1 other 4 Quote
Popular Post Ron Altier Posted February 3, 2021 Author Popular Post Report Posted February 3, 2021 3 minutes ago, Cal said: It came without the needed cords? Glad you had some that worked with it. Yes, that is why it was so cheap. I have a drawer full of old cords and USBs from old gifts and purchases. Cal, FlGatorwood, DuckSoup and 2 others 5 Quote
