November 22, 20205 yr 16 hours ago, HARO50 said: They wouldn't be using aluminum wire, would they? And would it actually make a difference? John I believe aluminum wire is to brittle to be used in an extension cord.
November 22, 20205 yr Popular Post 2 hours ago, HandyDan said: I believe aluminum wire is to brittle to be used in an extension cord. Maybe pot metal, then? John
November 24, 20205 yr Aluminum isn't necessarily brittle, but depending on annealing, can be very hard (or soft). My 4 aught service wire is aluminum and i have seen a lot of (what i consider to be lesser quality) jumper cables made of aluminum.
November 24, 20205 yr Popular Post 1 hour ago, p_toad said: Aluminum isn't necessarily brittle, but depending on annealing, can be very hard (or soft). My 4 aught service wire is aluminum and i have seen a lot of (what i consider to be lesser quality) jumper cables made of aluminum. You will want to check the lugs on the aluminum wire. I have seen it get loose from expanding and contracting in the hot and cold.
November 24, 20205 yr The major drawback to aluminum wire. Some towns out my way only allow it with the crimp-on lugs, which you then attach to whatever you are feeding.
November 24, 20205 yr Popular Post Back in the 70s there was a night club/supper club in northern KY. that caught fire and burned down, killing over 300 people (as I recall). The cause of the fire was the aluminum wiring used in the building. The expansion/contraction thing in the panel sparked the blaze. It was the Beverly Hills Supper club. I've been scared of aluminum wire ever since then.
November 24, 20205 yr Popular Post 34 minutes ago, Fred W. Hargis Jr said: Back in the 70s there was a night club/supper club in northern KY. that caught fire and burned down, killing over 300 people (as I recall). The cause of the fire was the aluminum wiring used in the building. The expansion/contraction thing in the panel sparked the blaze. It was the Beverly Hills Supper club. I've been scared of aluminum wire ever since then. We had quite a few fires caused by the same thing, so the Ontario government banned the use of aluminum wiring in houses for that reason. John
