June 1, 20206 yr comment_230799 Have a Black & Decker 7614 router that set idle for a long time. Is in almost new condition. Will turn by hand. But will not start when pressing trigger. Report
June 1, 20206 yr comment_230815 If you have dirt dobbers in your area this might be the problem....Things I don't use very often I just go ahead and take the time to check and use the air compressor before I ever flip the switch. And sometimes it takes some long skinny prods to loosen them up... I now use plastic bags on stuff not used often... Report
June 1, 20206 yr Popular Post comment_230818 If in a damp location possible corrosion at contact points. Really to know more you will need to open it up and check for power to trigger and then the wire that goes to motor itself. You can guess all day till you test that far. Report
June 1, 20206 yr Popular Post comment_230826 Sounds like corrosion on the trigger contacts. If you can fins some contact cleaner spray, it might do the trick. Report
June 2, 20206 yr Author comment_230848 Thanks for all the replies. No dirt dabbers. I was hoping I would not have to dig into it.... but. Will get out the contact spay and hope that will do it. I hope.............thanks again. Report
June 2, 20206 yr Popular Post comment_230853 38 minutes ago, Bob W. said: Thanks for all the replies. No dirt dabbers. I was hoping I would not have to dig into it.... but. Will get out the contact spay and hope that will do it. I hope.............thanks again. Dig in and post results or further questions. I walk people through diagnosing such problems regularly. If I can get my 15 year old daughter through a outlet repair over the phone I figure I am not too bad. I will admit afterwards some alcoholic refreshment was in order. Report
June 3, 20206 yr comment_230948 23 hours ago, Gunny said: I will admit afterwards some alcoholic refreshment was in order. for you or her? Report
