May 6, 20206 yr Popular Post comment_227721 With the hot tub out of this 10x12 building I now have a finishing room. Took down the ceiling fan and installed LED shop lights so we have plenty of light, but no ventilation. No problem, I built this using storm windows because with a hot tub you don't want expensive windows. Just something to keep the elements out. So since you can remove the glass panels for cleaning I decided to remove the upper one in a corner and designed a box to go through it. The hole is just large enough for me to be able to use a 16 inch attic fan, plenty of ventilation power with that! Took me an afternoon to make the box and cut out the front and back panels. I was deliberate in using alot of screws, I prefer to easily be able to access this if my prototype has issues. Ya never know and I certainly am not a design engineer expert. Started with the case. I braced the thing to death, paid off in the end NO vibration. Outside and inside case panels. And after a few days for the paint to cure. All done and working well. Installed aluminum screen on the outside to keep the bugs out. On the inside I used this 1/2 square mesh has a funny name like fabric mess or something. Either way it will keep fingers safe. Now if a bug goes in there, oh well welcome to the torture chamber. Now I am ready for the summer heat. Report
May 6, 20206 yr Popular Post comment_227726 Considering how thorough all of your work has been, I’m sure you installed an adjustable speed fan, controlled by a software program you designed, so that as the heat reading on the thermostat increases so does the fans CFM’s. (I wrote this tongue in cheek, but I figger it’s 50/50 I’m correct) Nice job. Report
May 6, 20206 yr Author Popular Post comment_227730 31 minutes ago, Artie said: controlled by a software program you designed, I have trouble turning the phone on some days. 32 minutes ago, Artie said: I’m sure you installed an adjustable speed fan, I did THINK about it. BUT wait, I did install a LIGHTED switch. Seems I had one in stock and thought, why not? Report
May 6, 20206 yr Popular Post comment_227733 Looks more like wire cloth to me. comes in several mesh sizes. good stuff to have around. Report
May 7, 20206 yr comment_227758 Inside wire is called hardware clothe here. At least for the past 50 years. It may have other names in other places. I talked about grass sacks and here they are called ruck sacks. Report
May 7, 20206 yr Author comment_227759 6 minutes ago, FlGatorwood said: hardware clothe That is it, I couldn't remember what it was called. Have had a large roll for years I use when needed. Report
May 7, 20206 yr comment_227780 This ought to help kick your finishing skills up a notch or two. I forget, does the finishing room have windows on the opposite wall? Report
May 7, 20206 yr Author comment_227787 1 hour ago, Cal said: This ought to help kick your finishing skills up a notch or two. I forget, does the finishing room have windows on the opposite wall? It has 8 ft of windows in two corners. Two on back wall and one on far wall plus the door. Lots of daylight. I will post better picture set tonight. Report
