  • 3 years later...
Posted
What blade are you using and how thick is the wood?
  • Like 2
Posted
Mike I buy ruff maple that is about 1 1/8" thick before planning which gives me at least 1" or more. Plus I use a backer board of at least 1/2" thick plywood. The backer board is because I scroll saw everything in to small sizes for I hold the pieces in my hand while using a Dremel and some very small angle air grinders which are small enough my open hand will cover up. Check Harbor Freight for the grinders are somewhere around 30 bucks.
   First I put a few screws in the outside of the backer which will give me 1 1/2" to saw through then saw away the waste wood.. Now before I saw any single piece away I pre drill  a hole or two so I will have a place to put each piece back in to the same area it came out of using an Olson # 5 precision cut reverse tooth blade for it saws faster than the Flying Dutchman #5's I use for all the inside cuts.
   Once I saw the outside away, I take the backerboard off  so now I am ready to saw the pieces out in areas that won't be noticeable when the project is completed.  I
Important, before I cut any small piece away I first drill a counter sink hole and put in a screw.....I do this to all the small pieces for when I am through carving I have a place for all the pieces to go as they were before I sawed them out..This give me the same width slots as the blade between all the pieces.
  I use sheet metal screws for the threads are the same width from top to the bottom and I counter sink a hole the size needed for the hole. To get the drill bit size I hold a screw behind a drill bit and all I want to see is the very edges of the threads and only just the  very small part of the threads. Doing this I don't get any cracks in the wood..  Not always for            sometimes the hole I drill is too close to the edge of the piece.
 When all the carving and finishing has been completed I put glue down and screw down the pieces and after that I can take out the screws and use them later if need be on another project or leave them in!.  this project took less than a week as I was also mowing the lawns. Jess, smallpatch
20240122_173237.jpg.1231106a25bfd5ea1c31bf2d9d463253.jpg20240122_173307.jpg.dcd800e108daf3183bf19b226c318bf4.jpg
Posted
Good to hear from you Patch. Hope all is well. Nice looking piece. I don't recall seeing this one before?
Posted
Thanks for the topic Jess! You are known as the "Master of the Grind!". And your creativity, I never tire of seeing your work Jess. Thanks for showing us what can be done with a grinder and dexterity.
  • Like 2
  Only 75 emoji are allowed.
