February 13, 20206 yr comment_218512 How many of you start your CNC cutting and then leave it? I designed a clock for my wife and the 3D carving is going to take around seven hours. I feel a little uneasy leaving it but that is a long time to stand there and watch it. Report
February 14, 20206 yr comment_218563 Rusty, is this a new machine for you? Don't recall you posting CNC stuff up before Report
February 14, 20206 yr comment_218626 I've been using my CNCs as well as the ones where I work for over 8 years now. Things that can go wrong include: - The wood starts to warp when much is cut from its face and can screw up the cut when that happens. - A cut might eventually have the router or router mount hitting a clamp/hold-down. Always messes up a project. - A bit may break during an extended cut. Doesn't always do damage when it happens, but the CNC won't notice and will waste time believing it is still cutting wood. - drilling operations can/might start a fire if using the wrong bit or too fast a plunge rate. - the board can come loose, usually messing up the project. - The PC, if not set up right, might decide to do an update and reboot when it should be controlling the CNC. - Using a router the brushes and/or bearings can go bad, and always during a cut. Might end up breaking the bit in use if stops spinning while the CNC is still moving it. I'm sure I've forgotten a few. Despite the above possible experiences I do occasionally let my CNC run while I work in another room. I can usually still hear enough from the CNC room that I notice when the sounds change and will check on it. 4D Report
February 14, 20206 yr Author comment_218634 10 hours ago, Cal said: Rusty, is this a new machine for you? Don't recall you posting CNC stuff up before Yes I am new. I was going to make a couple of small projects first. If I need to stay close then I can rough out some bowls on my lathe but that will limit me to doing it only when I have the time to stay out there. Report
February 15, 20206 yr comment_218730 Good luck with it Rusty, look forward to your posting some projects up! Report
February 15, 20206 yr comment_218743 Never leave it unattended.....that's when the real fun starts... Edited February 15, 20206 yr by BillyJack Report
February 16, 20206 yr Author comment_218769 9 hours ago, Cal said: Good luck with it Rusty, look forward to your posting some projects up! Thanks it shouldn’t be much longer. I had to order a few things and they are slowly coming in. Report
April 4, 20206 yr comment_223888 I don't leave mine while it's running and it seems if I turn around or take my attention from it for just a minute something will happen. Bits break, clamps get in the way even when you think you planned them not to. It's hard to sit there with it on a long run, but I don't like leaving it. I just turn the tv on in the shop and listen to whatever is on, I don't even watch it. Report
