November 30, 20196 yr comment_210760 I've got a Dewalt 788 scroll saw I have had for years. Don't use it much but I can't quit looking at the older Delta scroll saws. I just like Delta and can't help it Is the Dewalt better than the Delta and I need to quit looking or what?... Report
November 30, 20196 yr comment_210779 I'm not a heavy scroller, but I do have an opinion on the Dewalt 788. They are fine saws, and if yours is one of the earlier US models it's even better. I think the USA ones are type 1 on the motor label/ Someone will correct me if that's wrong. They might not be USA, but rather North American (Canadian) manufacturer. Either way, the newer ones are asian imports. Report
November 30, 20196 yr comment_210800 Can't tell you anything about the Dewalt, but if your talking something on the order of the Delta 1200/1440/40-440 they do have a following. I (barely) picked one up a couple months ago. They're pretty heavy. Not sure what I will do with it yet. Report
December 1, 20196 yr comment_210803 Billy Jack I think you would change your mind after you run both saws for a day each. Just changing blades on the Delta is a chore. And by the way the blade on that Delta almost looks like a hack saw blade its so big.....Scroll sawer users don't use that big anymore. The difference in those two saws are like night is to day...Lots of improvements since that Delta came out. Yes it will probably last your life time and a few more and it could be that no one will actually use it.. And that is just my opinion.... Report
December 1, 20196 yr Author comment_210812 Thanks for the replies. I don't know much about them as I don't do a lot of scroll sawing. I thought the Dewalt was pretty good but without using the others I would have no ideal... I just thought if the Delta was better I would look to go a headache purchase...Sounds like I already have a favorite.... Report
December 1, 20196 yr comment_210824 I don't know anything about them so here's some of my ignorance. I see that it has 4 bolt holes. Does it vibrate enough to bolt it down? It seems that if it vibrates that much, it would make it difficult to navigate small curves and corners while cutting. Report
December 1, 20196 yr comment_210842 There is quite an assortment of blades available for the old Delta machines. The 4 bolt holes are for bolting the machine to the stand. They are actually quite smooth running machines. Report
December 1, 20196 yr Author comment_210859 Seems like he dewalt would be a whole lot less work for the same results.... Report
December 1, 20196 yr comment_210862 Its been 50 years since I have sawed on that old Delta model and I do believe it takes pinned end only blades so any inside cutting would be limited. And back then I would opt for a jig saw instead of that monster...This Dewalt I bought in 99 and I can still stand up a dime on its edge on the table top while the saw is running and it is not bolted down and sits on two old pieces of old intertube. The older model just has a limited use but if you don't mind the amount of room it takes up why not. Report
December 1, 20196 yr comment_210864 That hold down attachment is the first thing you will do away with! Report
December 1, 20196 yr comment_210865 I don't think Delta has advanced as well as other companies when it comes to scroll saws. DeWalt 788 is a great saw, high ratings. My next move up is probably going to be the Pegas 21". Report
December 1, 20196 yr comment_210880 Bob not long ago Delta came out with one that almost looked like the 788 except for color. It was called 40-694 with all the same features. Evidently the patent ran out for them to copy the Dewalt. Report
December 1, 20196 yr comment_210882 33 minutes ago, Smallpatch said: I do believe it takes pinned end only blades 5" pinless blades. Report
December 1, 20196 yr comment_210888 47 minutes ago, Smallpatch said: Evidently the patent ran out for them to copy the Dewalt. I believe they're both owned by the same company now. Report
December 1, 20196 yr Author comment_210900 I eventually need to get mi e off the shelf and on a stand. I keep waiting on an original Dwalt stand but I may here to do something else. ... Report
December 2, 20196 yr comment_211020 I have a brand new stand I never used for I set my saw on a 20" tall table so I can sit on an office chair with wheels for I go back and forth to a work bench when I am sawing.....who ever thought a person should stand when using the scroll saw is nuts..... It is somewhere in my shop but the bolts and nuts might be another thing to find...pay the freight and its yours...I also think I have two more used tables that came with the 7 Dewalt 788's I bought from that school auction. Report
December 2, 20196 yr comment_211024 Probably half the time I spend in my shop is sitting in this seat and running the scroll saw...I usually have a piece of intertube under the front and back of the saw but when I cleaned out the area to take this picture, I moved it... the saw is not bolted down for when I saw wide pieces I have to slide the saw to the right or left for clearance on each side. I have a cheap box fan with a house furnace filter attached sitting on the side that the air tube blows the saw dust. About 20 years worth of pictures using the scroll saw can be found on my pictures here on the Patriot wood worker...The biggest size blade I ever use is a# 5 either in a Flying Dutchman or an Olson brand from The Teddy Bear which they just had a great sane on their blades and might still be going on! The Olson I use for more straighter cuts and the model I use is called the precision cut and if sawing curves it's the Flying Dutchman. Report
March 1, 20206 yr comment_220189 Bump it up a notch... http://www.bushtonmanufacturing.com/WebsitePages/The-Hawk-Scroll-Saw.html Report
