Posted
Same thing with latex paint. Not good for a shelf! Set something on it and it will stick!
  • Like 3
Posted
I prefer oil based paint for inside projects. Outside I use for a primer to seal the wood then top coat with latex.
For things I don't paint I stick with poly or lacquer.
  • Like 3
Posted
My understanding is that all latex is water based and not fit for exterior usage.  All exterior paint should be oil based as it seals itself to the target to protect it.  Latex should be good for walls and such, but for trim and where hands are going to be in regular contact, again, enamels or oil based.  The higher the gloss, the harder the coating and more protection.  Flat paints dries in beads so the when the light strikes it, the reflections go in different directions.  Gloss having a sheet like coating, reflects light and water in similar fashion.  At least, this is what I was taught in the early 70's in my apprenticeship in Graphic Arts.  This part I remember well is that look at flat paints as a stack of BB's.
  • Like 2
Posted
I've been painting my exteriors for about 30 years with latex, water based, and it seems pretty well suited.  We have some pretty aggressive sun and heat, and the paint will last 10--15 years (which is shorter than my wife's patience with any one color!).
  • Haha 3
Posted
Fred's right on.    I had a job a few years ago that were custom-built modular bookcases (think of a bunch of cubes in groups of 2-4.   They were sticking together.   Some I had to pry apart with a pry bar and it pulled off some of the wood veneer.   I patched all the damage and spot painted.   Then I applied a quality acrylic clear.   Let it dry for a full week.   And for insurance, applied a coat of paste wax to isolate the paint.   Must have worked as I never got a call-back.
Posted
I once used car wax on some shelves I put in for a family friend.  Seemed to work.
  • Thanks 1
  Only 75 emoji are allowed.
