November 21, 20196 yr Popular Post comment_209641 This will work for hard to hold parts. Just watched a video where the giuy had to machine a thin plate of aluminum, He wanted to use a very wide set fly cutter to clean up a cut path several inches across. As you can imagine the cutting forces in a large cut are substantial. But it was Thin so he couldn't squeeze it in a vice. They clean the surfaces, using acetone, dry them and apply blue tape to the mating surfaces. Then the take a clean hunk of somethign round and burnish the blue tape pressing and rubbing it. then they clean the tape and then apply Locktight pro super glue to one surface. They squeeze them together a, lamp it let the glue set and then do the machining operation. It Held~!!!!!!!!!! here's the vid. Report
November 21, 20196 yr comment_209670 Sign carvers and other router users use the same technique for holding templates on the work. Most spray the mating surface with accelerator first. It works great and is easy to disassemble. Cheaper than double stick tape, too. Report
November 22, 20196 yr Author comment_209687 4 hours ago, Gene Howe said: It works great I was staggerblasted that it stood up to the forces of machining. Metals require tons more force to work than wood. Report
