November 7, 20197 yr comment_208002 Ok so I have decided that I want to add some air filtration to my garage workshop. Right now the budget is pretty tight so I have been looking for a used system or a really good deal. I have only found one used unit and it is a Delta 50-868 and just needs a filter for $75 (I think I can get it cheaper because it needs filters). I have also found that Amazon has the WEN 3410 @ $126.38. Questions What is your opinion on these units? Is it worth the hassle buying the used one and get new filters or should I just buy the new one and call it a day? Report
November 7, 20197 yr comment_208005 Check out Craigslist or your local auction listings. I bought my Jet at auction for a little over $100. Report
November 7, 20197 yr comment_208009 I have the WEN. Got it thru Walmart "to store" delivery so there was no shipping. It's really quiet and I like the remote control option. The only down side is that it takes unusual sized filters so you can't sub a typical furnace pleated filter. The filters are available from WEN https://wenproducts.com/products/air-filtration-inner-filter-2-pack-90243-026-2 https://wenproducts.com/products/air-filtration-outer-filter-2-pack-90243-027-2 Report
November 7, 20197 yr comment_208010 I have a JDS that I bought when they first came out. I've also made one from a salvaged furnace fan blower, some plywood in a box around it, and a couple of furnace filters. It lacks the internal filters but better than nothing and only cost me some scrap plywood. It sits right now in my finish area and I let it run after I turn off the spray booth filter fan. It is a two-speed fan so I got a switch that runs high, low, and off. Report
November 8, 20197 yr comment_208019 30 minutes ago, kmealy said: I've also made one from a salvaged furnace fan blower, some plywood in a box around it, and a couple of furnace filters. Great idea! Report
November 8, 20197 yr comment_208031 4 hours ago, Larry Blighton said: WEN 3410 @ $126.38. I have this one, works well, I date the filters and try to stay on monthly blow outs of the outer filter. Inner has yet to be changed, but I have a box of extra filters for them as well. I change the filter out on 3 month intervals. Longer if I haven't done much shop work. Report
November 8, 20197 yr comment_208052 I have a old JDS one speed. It works but not the best there is. Also have a 3 speed Jet with three timer settings and It really puts out a breeze. The bag has been blown out after 2 being up two or three years but is in good shape. I started last year buying MERV 12 filters for both and they both use the same size. Report
November 8, 20197 yr comment_208076 The shop built units can be very effective and low cost. You will need a blower from a furnace, if you know anyone in the business you might be able to get one form them. I kept the one from my old furnace when I had it replaced. But put it in a plywood box, and then use furnace filters to clean the air. On the one I built I used 3, stacked sequentially. The last one was a Filtrete Ultra Allergen, catches the finest stuff. In front of that was a Fitrete Purple (not quite as tight) and in front of that one was a cheaper filter to catch the larger particles...this kept the more expensive ones in service longer. I suppose you could, as an alternative, bui;d the box to accommodate one of the commercially available sock filters like the purchased units use. Report
November 8, 20197 yr comment_208110 What is your opinion on these units? It depends on what you're trying to accomplish. The problem with typical air cleaners (of the size you mention) is that they turn out about 400 cfm air. In a 25x20x8 space, that's an air turnover every 10 minutes (and "real" capture of about twice that time, 20 minutes). If you want overall, slow, dust reduction, one of these running continuously will clear the room. OTOH, so will just waiting for the dust to drop to the floor. For overall dust clearance, I open the garage door, and I put a wall fan on a bracket that hangs from the ceiling at the closed end of the garage. I position my dust-making operation about 5--8' from the fan (in the direction of the open door); dust is blown away from me and eventually just precipitates out on the floor/driveway. That's the best cost/benefit arrangement you can get, but it is not going to work in Minneapolis (or, locally, ShowLow: internationally famous for inclement winter weather. sort of). I know the room air filters are popular, and they do eventually capture dust, but you're going to breathe in a lot of it before it gets to the filter. When choosing filters, pick one that is at least "merv 13" (cheap ones are merv 8 or unrated). The best (and yes most expensive) method is capture right at the tool before it gets in the air. Report
November 8, 20197 yr comment_208112 As mentioned on the other sites. $75 is a good price, but look at the inner filter.If its bad its not cheap.. Outer filter is nothing.. These work very good..... Report
November 8, 20197 yr comment_208113 inner filter....https://www.amazon.com/DELTA-50-859-3-Pocket-Filter-50-875/dp/B0000223B7 Report
November 8, 20197 yr Author comment_208116 17 minutes ago, BillyJack said: inner filter....https://www.amazon.com/DELTA-50-859-3-Pocket-Filter-50-875/dp/B0000223B7 I am going to go look at the Delta this afternoon, I really think that I can pick it up for less then the $75 asking price. Report
November 9, 20197 yr comment_208164 12 hours ago, Larry Blighton said: I am going to go look at the Delta this afternoon, I really think that I can pick it up for less then the $75 asking price. It is a good price, grab it and get it installed. Buy a extra filter and you are good for awhile. I was about to build my own when a friend gave me the WEN as a Christmas gift. Only expense I had was to buy 3 boxes of filters. Report
November 9, 20197 yr comment_208206 They definetly work . I keep mine above the work bench. When I was sanding doors for cabinets I could see in the sunlight coming through the window just how much it worked. Just don't let the second filter get over clogged Report
November 10, 20197 yr Author Popular Post comment_208223 I went and looked at the Delta Air cleaner today and it was in really nice condition, very clean and sounded great. I was able to pick it up for $60. I am going to replace both the inner and outer filters. Hopefully I will get it hung up in the next couple days while I am waiting for the inner filter to come in. Report
November 11, 20197 yr comment_208351 If you look on the back wall in the picture you can see the conduit comes down to a switch I use to turn it on. Very easy to set up Report
November 12, 20197 yr Author comment_208545 Quick update: The inner filter need replacing so I have ordered then from Wynn Environmental, they had a 2 pack for $69. They should be in late this week early next week. Will post update when I get it hung. FYI: Wynn Environmental offers a military discount of 15%. All orders have to be done over the phone to get discount. Report
November 12, 20197 yr comment_208553 29 minutes ago, Larry Blighton said: FYI: Wynn Environmental offers a military discount of 15%. All orders have to be done over the phone to get discount. Good to know, Thanks! Report
