August 28, 20197 yr comment_200037 Have anyone seen or had any experiences with the corner dowel kit shown in the AD? It looks good, but does not say if it requires a special drill or if you must drill from both sides to prevent splits or chips when the drill exits. Another question: Can it be used on picture frames? Report
August 28, 20197 yr comment_200045 Have to look into the how it works part. Looks interesting and certainly has a unique look when done. Report
August 28, 20197 yr comment_200103 The instructions provided by Rockler show the use of a backer against the outer face to prevent blowout. The catalos also shows various diameter drills - 6" long, which I'm assuming is because of the combined thickness of the joint - nothing is said about "special" drills so probably any quality brad point drill that has the required length would work. Report
August 28, 20197 yr comment_200104 Would the sides need to be glued together first and then drilled? Doesn't look like mush clamping area. Edited August 28, 20197 yr by HandyDan Report
August 29, 20197 yr comment_200114 Interesting idea, adds a bit of something different to the look of those corners. Watched the video, could see the backing piece used to prevent blowout. Presumably it's sacrificial and something you provide yourself, and doesn't impact on how you calculate the settings..... Report
August 29, 20197 yr comment_200124 4 hours ago, tomp said: Right off the Rockler web site Thanks for the post. Helpful in seeing how they approach using the jig. Now the moron that decided they needed that insane music, beat that guy with a stick! Report
August 30, 20197 yr Author comment_200210 I have decided not to look into this. My shop is so small that I would have to toss something out, to put in something new. I doubt I'd use it much anyway. Is that wisdom creeping in..............or ..........am I just getting old Report
