June 1, 20197 yr comment_192212 I'm not a builder but this video is compelling for exterior framing. Danl https://www.youtube.com/watch?v=mxDSulcLpAE Sales@Tstud.com www.stud.com Report
June 1, 20197 yr comment_192223 That's just too cool. From a builder's perspective, the labor savings alone would be substantial. For the home owner, the obvious long term advantages are worth every penny. Report
June 1, 20197 yr comment_192235 Now you attach your plastic electrical box to the stud, then you bring the cable (Romex) into the box. Code requires you to install a staple within 8 inches of the box, BUT you MUST be 1 1/2 inches from the edge of the stud so missed sheetrock screws won’t penetrate the cable. I don’t see how this would be possible with these studs, the other option is to mount supports on the studs to hold the cable, more work, more money. I’m sure they’ve figgered out a way to do this. Not having to drill through the studs is an advantage. I’m wondering if NEC has examined these from the electricians reference point. Didn’t watch the entire video, wonder what the cost difference is. Report
June 1, 20197 yr Author comment_192241 2 hours ago, Artie said: Now you attach your plastic electrical box to the stud, then you bring the cable (Romex) into the box. Code requires you to install a staple within 8 inches of the box, BUT you MUST be 1 1/2 inches from the edge of the stud so missed sheetrock screws won’t penetrate the cable. I don’t see how this would be possible with these studs, the other option is to mount supports on the studs to hold the cable, more work, more money. I’m sure they’ve figgered out a way to do this. Not having to drill through the studs is an advantage. I’m wondering if NEC has examined these from the electricians reference point. Didn’t watch the entire video, wonder what the cost difference is. See page 26,27 from the field guide. Danl https://static1.squarespace.com/static/59cce8bba9db0941ea92e75f/t/5b52301bf950b7bcf7e84090/1532112925219/FieldGuide.pdf Report
June 2, 20197 yr comment_192255 Interesting stuff. When I win the lottery I plan on trying it out..... Report
June 2, 20197 yr comment_192262 I can see the plumbers and electricians having issues with them, first couple of times they work with it. Also if they bid on a job, not knowing that these are the studs being used. Report
June 2, 20197 yr comment_192287 I think the regular 2x6 studs is the only way to go for walls...…. It looks to me like that will add much more labor cost with the new invention. Do I see just one header board on top of the stud wall. Report
June 12, 20197 yr comment_193200 Please check out infofast external insulation. https://www.insofast.com/explore/project-prep-before-you-install-insofast.html The EX 2.5 is eactly for what he is calling thermal bridging and much less expensive and better. Report
