March 17, 20197 yr comment_182809 I used some double sided tape to sitick my peieces togeher while I sanded the arc I had cut smooth and I cannot unstick them. Directions say heat the surfaces with a heat gun and once to hot to touch the tape should be pliable enough to peel them apart. My question is how to I heat the wood without hurting it. Bake it at 200F or use a heat gun and risk leaving burn marks. Help please Report
March 17, 20197 yr Author comment_182870 Would the solvent pollute the wood? I am sort of afraid of exposing the air dried oak to 200F. If the solvent won't harm the wood I will try that route. Report
March 17, 20197 yr comment_182875 Should be no issue using either Denatured Alcohol or Acetone. Worst it will do is slightly raise the grain since it's oak but assume you still have sanding and sealing to do yet anyway? FWIW, usually only a few small strips of double-side tape is needed to secure a template or two pieces together for sanding. Report
March 17, 20197 yr comment_182884 Acetone or, lacquer thinner works. Let it soak a bit. Doesn't affect the wood. Might need to wipe off the residual adhesive with more solvent. Report
March 17, 20197 yr Author comment_182945 Acetone, mineral spirits, alchol all failed. The only thing that worked was to bake it 200F for 30 min. Probably could have gone to 250F for 45. Then with considerable force I could move the peices apart limitedly. I think slipped in a thin knife and cut the glue in half. And it worked I parted them then got most of the glue off. Lesson learned never use this stuff again. Actually logging a correct Acetone is the solvet but you could not get enough of it in the joints to remove the adheavise. While attempt to clean the knife the Acetone works ge Edited March 17, 20197 yr by Michael Thuman Update Report
March 17, 20197 yr comment_182949 1 hour ago, Michael Thuman said: Acetone, mineral spirits, alchol all failed. The only thing that worked was to bake it 200F for 30 min. Probably could have gone to 250F for 45. Then with considerable force I could move the peices apart limitedly. I think slipped in a thin knife and cut the glue in half. And it worked I parted them then got most of the glue off. Lesson learned never use this stuff again. Try using smaller pieces on some scraps. I had the same problem and in this case sometimes less is more. I use what they call turners tape and have good success with it. You may also want to check this video too. Report
