February 21, 20196 yr Popular Post Hey folks! I'm a new turner. Just been making shavings trying to learn the tools but I think I'm ready for my first project. I need some tool handles for some carbide turning tools I picked up. I have quite a bit of sassafrass just lying around so I think that would make some good handles. I'll be posting pics (of course) and I'm open to any and all critiques, tips and general advise. The pieces are about 8", 9" and 10" long by about 2.5" in diameter. My first step will be to shape the handles, then I need to find something to use as ferrules before attempting to mount the tools. Thanks for putting up with "the new guy".
February 21, 20196 yr Popular Post Thad - welcome to TPW! Copper pipe makes a beautiful ferrule, easy to cut, sand, polish and finish. Good luck with the handles!
February 21, 20196 yr Author Popular Post 7 minutes ago, Jim from Easy Wood Tools said: Thad - welcome to TPW! Copper pipe makes a beautiful ferrule, easy to cut, sand, polish and finish. Good luck with the handles! Thanks for the tip. I just watched Mike Peace's handle making video and he suggested the copper pipe or even copper couplings. By the way....sassafrass smells AWESOME when you're turning it! Edited February 21, 20196 yr by Thad Adding content, spelling
February 21, 20196 yr Popular Post We are looking forward to seeing those handles! Sometimes, using a branch centered on the turning can cause some cracking problems as it dries. If you have something large enough to split and avoid the pith, it may give you a little better turning. As Jim said, copper pipe makes great ferrules! Also, depending on what you have available, large brass compression fitting sill also work but may need some shaping on the outside- depending on what you are making.
February 21, 20196 yr A couple of notes about Sassafras. I've heard some folks have a reaction to it- https://www.wood-database.com/sassafras/ https://www.wood-database.com/wood-articles/wood-allergies-and-toxicity/
February 21, 20196 yr Author 8 minutes ago, lew said: Sometimes, using a branch centered on the turning can cause some cracking problems as it dries. If you have something large enough to split and avoid the pith, it may give you a little better turning. Thanks for the tip. I don't have anything that big right now. The handles will be relatively small so I'm hoping that will cut down on some of the splitting. 6 minutes ago, lew said: A couple of notes about Sassafras. I've heard some folks have a reaction to it- https://www.wood-database.com/sassafras/ https://www.wood-database.com/wood-articles/wood-allergies-and-toxicity/ Thanks for the heads up. I've been around sassafrass a lot. I still enjoy making sassafrass tea occasionally. Also, I use a particulate mask and faceshield when turning. I work as a safety rep for the oil and gas industry, so if any of my guys saw me without the proper PPE, I would never hear the end of it.
February 21, 20196 yr Author Popular Post First handle roughed out......Now, on to the shaping! Edited February 21, 20196 yr by Thad
February 21, 20196 yr Popular Post Late to the party here but it looks like you're in good hands and already have a lot of good advice. Mike Peace is a very accomplished turner and he does good videos so you made a great choice learning from him. I will add that I make almost of my own handles and I also use copper pipe, rather copper couplings as they are just a little larger in diameter and I can get two ferrules from one coupling. Looking forward to your finished pics and welcome to the vortex!! Steve
February 21, 20196 yr Author Finally finished with the shaping. Then some BLO, drill the hole and set the tool. Looks like crap, off center, not very aesthetically pleasing, but it'll do 'til I build another one (and another.....and another....). Next time, I'll start with better and bigger stock and will have more of a plan for the finished product rather than just "winging it".
February 21, 20196 yr Looking good. With the metal shank being so I assume you will be doing pens. The handle needs to be longer if you plan on using it for bigger stuff for control purposes.
February 22, 20196 yr Author Popular Post 10 minutes ago, HandyDan said: Looking good. With the metal shank being so I assume you will be doing pens. The handle needs to be longer if you plan on using it for bigger stuff for control purposes. Definitely some design changes to be made for the next one. I'm just glad to have finished a project. Lots learned this go round.
February 22, 20196 yr Popular Post You have to start somewhere, and starting is usually the hardest part. Don't beat yourself up to bad about the 1st one, heck I can show you lots worse to include some pens that I keep around. And I am by no means a turning expert. Stay at it. I look forward to seeing the next creation.
February 22, 20196 yr Popular Post That is a start. To help with centering the tool it is best to drill the hole with the workpiece on the lathe before final shaping. Then place the cone center on the tailstock and place the drilled hole over it. This will give you a centered straight hole to mount your tool every time. You might want to look at the Thompson Lathe Tools site for a article on making handles including how to mount a tool with a flat tang. Edited February 22, 20196 yr by Gerald
March 5, 20196 yr On 2/21/2019 at 7:04 PM, Thad said: Definitely some design changes to be made for the next one. there always are. I made mine so that I can wrap my hand around for a good gt rip and long enough so I can tuck 'em under my arm if I feel the need. I haven't done that yet. I prefer steel over copper for ferrules copper is easy to find but will stretch and deform easily which a good ferrule should never do. I dunno what that tool is it sort of looks like a braised carbide metal lathe tool. Have you gotten into looking at tools yet? Thompson is a nice place to start they are made of powdered metal and you can not easily distemper them by being too enthusiastic when grinding http://thompsonlathetools.com/product-list/
March 5, 20196 yr 8 minutes ago, Cliff said: by being too enthusiastic when grinding ...or Easy Wood Tools- no grinding at all
March 5, 20196 yr 4 hours ago, Cliff said: there always are. I made mine so that I can wrap my hand around for a good gt rip and long enough so I can tuck 'em under my arm if I feel the need. I haven't done that yet. I prefer steel over copper for ferrules copper is easy to find but will stretch and deform easily which a good ferrule should never do. I dunno what that tool is it sort of looks like a braised carbide metal lathe tool. Have you gotten into looking at tools yet? Thompson is a nice place to start they are made of powdered metal and you can not easily distemper them by being too enthusiastic when grinding http://thompsonlathetools.com/product-list/ If you have a thick enough tenon to mount the ferrule the material used is a mote point because usually the wood will break first anyway.
March 6, 20196 yr 7 hours ago, Gerald said: because usually the wood will break first anyway. I have always thought that preventing the wood from a failing was precisely why a ferrule is used. At least that's why I use them. The stronger material holds the wood tightly. My ferrules are hammered on. It's a substantial interference fit. Which latter point is another reason not to use a soft material with a low youngs modulus because it'll deform easily. Edited March 6, 20196 yr by Cliff
March 6, 20196 yr 56 minutes ago, Cliff said: I have always thought that preventing the wood from a failing was precisely why a ferrule is used. At least that's why I use them. The stronger material holds the wood tightly. My ferrules are hammered on. It's a substantial interference fit. Which latter point is another reason not to use a soft material with a low youngs modulus because it'll deform easily. My point exactly . The metal used is not significant as it will be the last to fail. There is still a weak point past the ferule where the wood is thin , before it gets thicker.
March 6, 20196 yr Popular Post 1 hour ago, Cliff said: low youngs modulus For those wanting to know as I did what this means: Young's modulus measures the resistance of a material to elastic (recoverable) deformation under load. A stiff material has a high Young's modulus and changes its shape only slightly under elastic loads (e.g. diamond). A flexible material has a low Young's modulus and changes its shape considerably (e.g. rubbers).
