November 10, 20188 yr comment_166002 Never ever throw any wood away for sooner or later I can find a use for it. Some of it is stored under the pickup in the garage.. I keep stacking it under there till I push a 2x4 out the other wall then I know its one too many high. Last place I could find a little spare space.... She needs a few pieces for her Nativity Scenes she has orders for.. I had to make a flap- lid on top of the funnel for the dust and shavings on the router table to be able to put the crank in the hole to raise and lower the router. It gets kind of tight in here when I push the router in here so I can use a dust extractor instead of the Sears vac. Can you spot the 2 other routers ? Can you see me in the mirror in the last picture? There is no mirror on that wall, its a rag I keep over the 7518 router mounted on the wood mill. Report
November 10, 20188 yr comment_166006 If it doesn’t get sucked up the 1.5” shopvac hose, it’s big enough to keep Report
November 10, 20188 yr comment_166013 Yes Jesse, I see you. At 1st then you asked if we could see you, I thought that I only saw a lot of wood and thought you were like Waldo, but there you were. Danl Report
November 10, 20188 yr comment_166020 2 hours ago, Smallpatch said: Can you spot the 2 other routers ? One and two Do I win the prize? 2 hours ago, Smallpatch said: There is no mirror on that wall, its a rag I keep over the 7518 router mounted on the wood mill. Oh, that would make three then; face fooled me... Report
