October 22, 20188 yr comment_163563 I want to reduce the thickness of a plastic (unknown composition) cutting board from Walmart. Tried the DW735 with the straight blades and the board shattered. I was only taking a 32nd off. Maybe a router planing jig would work??? Or, may wait till the Shelix head is installed in the planer??? Any ideas? Report
October 22, 20188 yr comment_163570 For the cost of the Shelix head, do you wanna risk it on plastic? Report
October 22, 20188 yr comment_163582 35 minutes ago, Gene Howe said: Tried the DW735 with the straight blades and the board shattered. I was only taking a 32nd off. must be in the acrylic family... UHMW planes... polycarbonate does too (LA)... go buy what ya need... Report
October 22, 20188 yr Popular Post comment_163589 I would not use a planer for that purpose, but I would use a drum sander for that purpose. I had been asked by the operator of my local Chick-fil-a run some plastic-type cutting boards to get them cleaned up from all the cutting. NOTE: these were not used for cutting chicken but for other items. They were about 3/4 to 7/8" thick and ran them through the Jet 16/32 drum sander. Once I got them all sanded and gave them back to the operator he was very happy. I did this twice for him before they got too thin. Report
October 22, 20188 yr comment_163593 37 minutes ago, Allen Worsham said: I would not use a planer for that purpose, but I would use a drum sander for that purpose. I had been asked by the operator of my local Chick-fil-a run some plastic-type cutting boards to get them cleaned up from all the cutting. NOTE: these were not used for cutting chicken but for other items. They were about 3/4 to 7/8" thick and ran them through the Jet 16/32 drum sander. Once I got them all sanded and gave them back to the operator he was very happy. I did this twice for him before they got too thin. Answer (Solved) Good one Allen Report
October 22, 20188 yr Author comment_163608 Unfortunately, I don't have a drum sander/thicknesser. I do have a Flat Sander, though. I'll give it a try. I'm trying to make ZCIs for my Smithys. Report
October 22, 20188 yr comment_163610 how thick do you need... acrylics aren't the way to go.. too brittle... Report
October 22, 20188 yr comment_163611 would a rabbet or or a counter bore give you the thickness you need??? Report
October 22, 20188 yr comment_163618 Gene I use the Walmart cutting boards on all my extra long clamp pads I adapted to use on my Vise Grip c clamps but I just use the thickness the boards are.. Whats a VCI and I do know what Smithy's are for I use to have a set on my chevy. So why need an exact thickness? Report
October 22, 20188 yr comment_163620 it's ZCI and it stand for Zero Clearance Insert. those that have table saws know this... Report
October 22, 20188 yr Author comment_163622 2 hours ago, Stick486 said: would a rabbet or or a counter bore give you the thickness you need??? Yes! In fact, that's how I make them from wood. May need to do it that way. Report
October 23, 20188 yr comment_163633 39 minutes ago, Gene Howe said: Yes! In fact, that's how I make them from wood. May need to do it that way. That is how I do it too, a rebate around the edges. But beware,with the thicker ZCI you may have to relieve the center for the saw washer. I have to and I use a dado which is a smaller diam. on the arbor ,set the ZCI and slowly raise it to cut the underneath of the ZCI a tad for the arbor washer to clear. Herb Report
